Parts List Check
Parts List Check
Parts List Check
I have a checking rule where a part of it iterates through a parts list. However, when there's no parts list it errors.
The reason is the initial call....
Dim oPartList As PartsList
oPartList = oDoc.ActiveSheet.PartsLists.Item(1)
So if a drawing has no parts list, how can I make it jump over this.
Vladimir.Ananyev
You may check PartsLists.Count property value.  If it is equal to 0, then  partslists collection is empty.
  Dim oDrawDoc As DrawingDocument
  Set oDrawDoc = ThisApplication.ActiveDocument
  Dim oSheet As Sheet
  Set oSheet = oDrawDoc.ActiveSheet
  If oSheet.PartsLists.Count > 0 Then
    Set oPartList = oSheet.PartsLists.Item(1)
  Else
    'oSheet does not contain any PartsList
  End If
 cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
