@Anonymous,
To extrude feature through Inventor API, it needs sketch definition and sketch entities (lines, arcs, etc). After creation of sketch, sketch should be closed loop. Try below VBA code to recreate extrude feature in part.
Public Sub ExtrudeFeature()
' Create a new part document, using the default part template.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Create a new sketch on the X-Y work plane.
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
' Set a reference to the transient geometry object.
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
Dim oCenter As Point2d
Set oCenter = oTransGeom.CreatePoint2d(0, 0)
' Create a sketch circle
Dim oCircle As SketchCircle
Set oCircle = oSketch.SketchCircles.AddByCenterRadius(oCenter, 1)
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create a base extrusion 4 cm thick.
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(1, kPositiveExtentDirection)
Dim oExtrude As ExtrudeFeature
Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
