Part QTY from BOM
Part QTY from BOM
william
Part QTY from BOM
william
Hello
I am looking to get the Qty from the bom for a component or a virtual component. Capture.JPG
Just about all posts I have read on this loop through all bom rows to get the quantity, but I only want to get the qty for a specific part.
The API diagram shows BOMQuantity as accessible from the VirtualComponentDefinition without having to go through the BOM object. API Diagram.JPG
Is there a simple oneline I can use for this?
Starting code,
Dim oAsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oOccs = oAsmCompDef.Occurrences
For Each oOcc In oAsmCompDef.Occurrences
	If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
		If oOcc.Name.Contains("REF_RAIL") Then
			strQTY = oOcc.BOMQuantity()
			MessageBox.Show("QTY = " & strQTY, "Title")
		End If
	End If
Next
theo.bot
With the BOMQuantity object you can set the QTY option for that component like you can do using the document settings.
if you want a one line code you need to now the rownumber of your component.
oDoc.ComponentDefinition.BOM.BOMViews.Item("Structured").BOMRows.Item(1).TotalQuantity
like the other post are telling you, a small loop will work to find the row and get your totalquantity.
william
Ok, thanks.
