Part Numbers of Content Center Parts
emanuel.c
emanuel.c
I usually give Part Numbers to Parts through the BOM. The CC parts always rename "Part Number" by their defaults if there are any changes. For this reason I create an additional iProperty "Number" which stores the "Part Number" value so that it doesn't dissapear after every change. Then I have to again set Part Number = <Number> in BOM to fix the issue.
I wrote this little code to:
  • unmerge BOM
  • set Part Number =<Number> (yes I even tried giving it a copied valued instead of formula)
  • re-merge BOM
But it still doesn't work. The part's which are of same stock size and same length still cause issues.
So I manually un-merge and I have this (none of the parts are named the same):
Next, I retype the Number values - same values as before (essentially 'dirtying' the part) and everything works well.
How can this be fixed? I tried "dirtying" the part through the code with: oRefDoc.Dirty = True, oRefDoc.Update() but without any success...
Here is the code. Many thanks!
Sub Main()
    Dim oAsmDoc As Document = ThisApplication.ActiveDocument
    If oAsmDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        MessageBox.Show("Run this rule on an ASSEMBLY document. Exiting...", "ERROR",
                        MessageBoxButtons.OK, MessageBoxIcon.Error)
        Exit Sub
    End If
    ' Disable merge before updating Part Numbers
    Bom_DisableMerge(oAsmDoc)
    ' Update Part Numbers from iProperty "Number"
    UpdatePartNumbersFromNumber(oAsmDoc)
    ' Re-enable merge
    Bom_EnableMerge(oAsmDoc)
End Sub
Public Sub Bom_DisableMerge(oAsmDoc As AssemblyDocument)
    Dim oBOM As BOM = oAsmDoc.ComponentDefinition.BOM
    oBOM.PartsOnlyViewEnabled = True
    ' Disable "Merge Rows on Part Number Match"
    oBOM.SetPartNumberMergeSettings2(False, Nothing, Nothing)
End Sub
Public Sub Bom_EnableMerge(oAsmDoc As AssemblyDocument)
    ' Enable "Merge Rows on Part Number Match"
    oBOM.SetPartNumberMergeSettings2(True, Nothing, Nothing)
End Sub
Public Sub UpdatePartNumbersFromNumber(oAsmDoc As AssemblyDocument)
    For Each oRefDoc As Document In oAsmDoc.AllReferencedDocuments
        ' Skip non‑modifiable and non‑real BOM parts
        If Not oRefDoc.IsModifiable Then Continue For
        If oRefDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Then Continue For
        If oRefDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then Continue For
        ' Get custom property set
        Dim oCustom As PropertySet
        Try
            oCustom = oRefDoc.PropertySets("Inventor User Defined Properties")
        Catch
            ' No custom props → skip
            Continue For
        End Try
        ' Try to get "Number"
        Dim numberValue As String
        Try
            numberValue = CStr(oCustom("Number").Value)
        Catch
            'MessageBox.Show("Didn't work for: " & oRefDoc.DisplayName & " (no 'Number' iProperty)")
            Continue For
        End Try
        If Trim(numberValue) = "" Then Continue For
        ' *** FORCE REFRESH OF NUMBER ***
        oCustom("Number").Value = numberValue
        ' *** Assign formula-style reference to Part Number ***
        Dim oPNProp As Object
        Try
            oPNProp = oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number")
            oPNProp.Value = "=<Number>"
        Catch
            'MessageBox.Show("Didn't work for: " & oRefDoc.DisplayName & " (no 'Part Number' iProperty)")
            Continue For
        End Try
    Next
End Sub
dalton_northwind
Maybe try updating the assembly file along with the parts.
We had a similar problem and from what I remember we had to uncheck a frame generator setting. attached
emanuel.c
@dalton_northwind Thank you so much!! I can't believe I've been using Inventor for so many years and never knew of those settings! That auto renaming was always a frustration. I'll call this solved.
emanuel.c
Meanwhile I was able to adapt the code using Rebuild and Refresh on the BOM. If it's useful to anyone, here it is:
Sub Main()
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
        Exit Sub
    End If
    ' 1. Disable merge before updating Part Numbers
    ' 2. Update Part Numbers from iProperty "Number"
    ' 3. Force assembly update AFTER parts update
    Try : oAsmDoc.Update2(True) : Catch : End Try
    ' 4. Full BOM rebuild sequence
    RebuildBOM(oAsmDoc)
    ' 5. Re-enable merge
    ' 6. Final assembly update
End Sub
' DISABLE MERGE
End Sub
' ENABLE MERGE
End Sub
' UPDATE PART NUMBERS FROM "Number"
        Try
        Catch
            Continue For
        End Try
        Try
        Catch
            Continue For
        End Try
        ' Refresh Number
        ' Assign formula Part Number
        Try
        Catch
            Continue For
        End Try
        ' Dirty the document
        ' Force iProperty evaluator
        Try : oRefDoc.PropertySets.Flush() : Catch : End Try
        ' Rebuild geometry
        Try : oRefDoc.ComponentDefinition.Update() : Catch : End Try
        ' Update document
        Try : oRefDoc.Update2(True) : Catch : End Try
        ' ⭐ CRITICAL ⭐ Save forces formula evaluation
        Try : oRefDoc.Save() : Catch : End Try
    Next
End Sub
' FULL BOM REBUILD SEQUENCE
Public Sub RebuildBOM(oAsmDoc As AssemblyDocument)
    ' Ensure BOM views are enabled
    oBOM.StructuredViewEnabled = True
    Dim oStructured As BOMView
    Dim oPartsOnly As BOMView
    Try
        oStructured = oBOM.BOMViews.Item("Structured")
        oPartsOnly = oBOM.BOMViews.Item("Parts Only")
    Catch
        Exit Sub
    End Try
    ' Rebuild both views
    Try : oStructured.Rebuild() : Catch : End Try
    Try : oPartsOnly.Rebuild() : Catch : End Try
    ' Refresh both views
    Try : oStructured.Refresh() : Catch : End Try
    Try : oPartsOnly.Refresh() : Catch : End Try
    ' Update assembly
End Sub
