Part iLogic yes, within an assembly no.
awatt
awatt
I have a part that currently triggers an external iLogic routine (simple alert box) on the On Open trigger.
What I DON'T want, is for this box to appear when an assembly that contains the part is opened.
What are my options?
MegaJerk
Something like :
If ThisApplication.ActiveDocument.DocumentType <> _
kPartDocumentObject Then
	Return
End If
 that, at the top of the rule should work.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
awatt
Thank you.  That worked perfectly.
I considered looking for something like this, but I assumed iLogic would be too myopic to see outside of the part that called it.
