Part file sketch text height problem
Hi all,
I've got a really simple problem, I just can't figure it out.
I'm trying to change the font size of the text in a text box using the following code.
Sub TextHeightTest()
Dim odoc As PartDocument
Dim textbox As textbox
Dim fontsize As Double
Set odoc = ThisApplication.ActiveDocument
Set textbox = odoc.ComponentDefinition.Sketches.Item(1).TextBoxes.Item(1)
fontsize = 0.35
textbox.Style.fontsize = fontsize
End Sub
but I keep getting error message saying that "Method 'FontSize' of object 'TextStyle' failed".
Has anyone got any suggestions?
Thanks and Regards
Figured it out...
Textbox.Styles.FontSize is not available for textboxes in parts or assemblies, only for textboxes in drawing documents
So... What you have to do is wrap your text in 'styleoverride' modifier...
My example ended up like this...
textbox.formattedtext = "<StyleOverride FontSize='0.35'>TEST TEXT</StyleOverride>"
End Sub
I've highlighted in red the bits that need to be added to the text....
What else can you control with the <StyleOverride> tag? Any documentation? I need to control the stretch of the text to squeeze it into a text box.
But text in formatted text is defined.(TEST TEXT)
How could we place occurrence names instead???
how colud we change font size of automated text in Sketch??
ANy suggesstions??
Hi guys,
My suggestion is to create a text box (manuall) using what ever formatting, fields etc that you desire. Then use VBA to get that object and view the formatted text object, and that'll give you the infomation you need.
I expect that you'll be able to control all the typical format methods (bold, italics, size, font, etc etc) and you'll also be able to add iproperties, and some other properties exposed to the text box tool...
Basically, if you can create it with a textbox in the GUI, then you'll be able to replicate it in vba.
Hope that helps.
Cheers
