Part dimensions don't change with assembly, parameters matched with 'A_...'
Can anyone help with this?
I'm creating a simple sub assembly of about 10 parts.  The sub assembly is placed into a main assembly as several different 'ilogic components' and each one modified differently.  Then a bill of materials from the main assembly.
I've matched the dimension parameters between the sub assembly and corresponding parts, but the part dimensions don't change when I change the dimension parameters in the sub assembly (I have to change the dimension parameter in each part in turn).  I learned from Autodesk Support that Inventor doesn't do what I'm asking without a degree of coding.
johnsonshiue
Hi! It is unclear to me what the issue is without seeing an example. You mentioned that you have contacted Autodesk Product Support. Do you have a case ID? I would like to understand the case better.
Many thanks!
Software Test Engineer
Autodesk Support CaseNo:13784591
PaulMunford
Please could you post your iLogic code?
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
