IMPORTING POINTS FROM EXCEL TO INVENTOR
khushank.ks
khushank.ks
I want to import several points into inventor from excel.
The points in my excel spreadsheet are such that two consecutive rows contain the two end points of a line and the next two rows contain coordinates for another line.
Like:
1 2
3 4
2 3
5 6
Here, (1,2) and (3,4) are the end points of one line; (2,3) and (5,6) are the end points of the other line.
But when i import this into inventor, instead of making two separate lines, it connects all the points together.
How can it be done?
johnsonshiue
Hi! I think this will have to be done via iLogic rule or VBA. There should be sample code for you to reference. Please take a look at the Solution#3 in below thread. You can add some code to create lines based on the points. Make sure you skip every two rows. to create a line.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticle...
Many thanks!
Software Test Engineer
khushank.ks
This file does not load in the VBA editor.
It keeps on showing "No open projects".
Xun.Zhang
@khushank.ks,
Here is an example for VBA to handle import point and make a spline though them all.
Hope it helps a little bit.
Sub CreateOneSpline()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSk3d As Sketch3D
    Set oSk3d = oDoc.ComponentDefinition.Sketches3D(1)
    Dim oPoints As ObjectCollection
    Set oPoints = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oPt As SketchPoint3D
    For Each oPt In oSk3d.SketchPoints3D
        oPoints.Add oPt
    Next
    Dim oNewSk3d As Sketch3D
    Set oNewSk3d = oDoc.ComponentDefinition.Sketches3D.Add
    Dim oSkSpline3d As SketchSpline3D
    Set oSkSpline3d = oNewSk3d.SketchSplines3D.Add(oPoints, kSmoothSplineFit)
End Sub
Xun
S_May
Hi @khushank.ks,
You can practice with this...
2018-01-15 12_39_20-Autodesk Inventor 2016 - [3D-Oberflächenstruktur.ipt].png2018-01-15 13_16_58-Modelle über Excel S_May.rar - WinRAR (Nicht lizensierte Testversion).png
