part and assembly reference in drawing
Message 1 of 32
ihi!
I wonder if it's possible to see with ilogic if a part exciste in all others view (in assembly) of the same sheet?
Thanks for your help!
Replies (31)
Message 21 of 32
hi Wayne!
I have a error message for this entry
oCompDef=selObj.Parent.ModelGeometry.Parent.ComponentDefini?tion
Message 22 of 32
wayne.brill
What is the error and what is selected? It is working for me when I select an edge of a part in a drawing view. (not an edge of an assembly in a drawing view)
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 23 of 32
If i selecte a edge of part in any view i have this message, i try with selection before and after the rule and same error message!
Message 24 of 32
wayne.brill
I used a translator and got this:
"End of statement expected"
It could be that something happened in the copying of the rule. Please attach your file with the rule so I can try to recreate the problem. I attached the .idw I am using.
Wayne
Wayne Brill
Message 25 of 32
is the same file test123 with your rule!
Message 26 of 32
wayne.brill
Ok, please upload your assembly (all the files I need to recreate the error). I do not know why the error is not occurring on my system and is on yours.
Wayne Brill
Message 27 of 32
this is the file!
Message 28 of 32
wayne.brill
I was able to recreate the error with the file you provided. (I got other errors about missing external rules and a missing reference too).
I find that if getting the ComponentDefintion is done in two steps that error was resolved. I attached the idw with this change. Does this help?
Here is a code snippet with the update:
If oDoc.SelectSet.Count > 0 Then
'Get the first selected entity
selObj = oDoc.SelectSet(1)
'MessageBox.Show(TypeName(selObj), "Title")
'see if the selected entity is a DrawingCurve
If TypeName(selObj) = "DrawingCurveSegment" Then
'get the name of the file the selected DrawingCurveSegment is in
Dim oModelGeometry = selObj.Parent.ModelGeometry
Dim oCompDef
'oCompDef = selObj.Parent.ModelGeometry.Parent.ComponentDefinition
oCompDef = oModelGeometry.parent.componentdefinition
partNameToTest = oCompDef.Document.DisplayName
'MessageBox.Show(partNameToTest, "Title")
Else
Wayne
Wayne Brill
Message 29 of 32
it'S possible to save in Inventor 2013, i have this error message when i try to open your file!
Message 30 of 32
wayne.brill
Here is a 2013 file with the updated rule.
Wayne
Wayne Brill
Message 31 of 32
Hi Wayne!
All your rules work great, i retry what i want to make, this select edge of part in view, if this part exciste in all others view in sheet run another rule or enter more code!
Thanks for all!
Message 32 of 32
anybody can help me for that?
