part and assembly reference in drawing
Message 1 of 32
ihi!
I wonder if it's possible to see with ilogic if a part exciste in all others view (in assembly) of the same sheet?
Thanks for your help!
Replies (31)
Message 2 of 32
wayne.brill
I am not sure I understand exactly what you need but here is a rule that I came up with using the Inventor API. In my tests I have several views and am cropping them so that it only shows some of the drawingcurves. When I run the rule it tells me correctly if an occurrence is showing in that view or not.
Notice that it uses the DrawingCurves property of the DrawingView and passes in an occurrence. The returned DrawingCurvesEnumerator will be different for each occurrence. (if it is not showing in the view the count is zero) This could be enhanced to handle sub assemblies. Currently it is just testing the top level occurrences.
 Dim oDoc As DrawingDocument
 oDoc = ThisDoc.Document
 Dim oDrawView As DrawingView
 For Each oDrawView In oDoc.ActiveSheet.DrawingViews
       Dim refDocDesc = oDrawView.ReferencedDocumentDescriptor
       Dim oAssembly = refDocDesc.ReferencedDocument
      Dim oOcc As ComponentOccurrence
      For Each oOcc In oAssembly.ComponentDefinition.Occurrences
           Dim oDrawCrvsEnum As DrawingCurvesEnumerator
           oDrawCrvsEnum = oDrawView.DrawingCurves(oOcc)
           If oDrawCrvsEnum.Count > 1 Then
               myString = myString & oOcc.Name & " is showing in " & oDrawView.Name & vbCr
           Else
              myString = myString & oOcc.Name & " is NOT showing in " & oDrawView.Name & vbCr
       Next 'occurrence
       Next 'DrawingViews
MessageBox.Show(myString, "Title")
I believe something like this can meet your requirement.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 3 of 32
Thanks Wayne for your reply 🙂
i test that today!
Message 4 of 32
work great Wayne 🙂
I have change your rule for my application, if in this list my selection part in view (NOM) exciste, i enter more code
entity = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kDrawingViewFilter,
"SÉLECTIONNE UNE VUE")
modelName = IO.Path.GetFileName(ActiveSheet.View(entity.Name).ModelDocument.FullFileName)
NOM = Left(modelName, Len (modelName) -4) & ":1"
myString = myString & oOcc.Name & vbCr
Else If oOcc.Name = NOM Then 'if name in list = NOM
Goto MESSAGE
Else
Next 'occurrence
Next 'DrawingViews
MESSAGE:
'MORE CODE HERE......
Sorry for my horrible english 😞
Message 5 of 32
my selected part in view
Message 6 of 32
it's not a solution it's a question for you 😉
i want to know if it's possible, if my selected part (NOM) exciste in this list show a message or enter more code?
And if i have a PresentationDocument in this page the rule dont work?
Message 7 of 32
dont work too if i have a sub assembly in assembly
Message 8 of 32
wayne.brill
Can you attach a set of files that will allow me to recreate this problem and researh for a solution?
Wayne Brill
Message 9 of 32
Thanks again Wayne for all your reply and help!
Message 10 of 32
wayne.brill
Here is a rule that has a recursive function (it can call itself). This rule gets the parts and sub assemblies of the selected drawing view in my tests. I am still not sure if this is what you need but I hope this can show how  you can get to the subassemblies. You can edit this and pass in the occurence or part to a call to DrawingView.DrawingCurves() to determine if that sub assembly or part is displayed in a drawing view.
Also I do not see an .ipn file in the attachments. Please explain what I need to do to recreate the error you mention.
'wB added Sub Main
Sub Main()
               "SLECT VIEW")
NAME = Left(modelName, Len (modelName) -4) & ":1"
'MessageBox.Show(NAME, "Title")
'wB commented
'Dim oDrawView As DrawingView
'wB added
Dim oDrawView As DrawingView = entity
'wB commented
'For Each oDrawView In oDoc.ActiveSheet.DrawingViews
'wB added
myString = "Top level assembly = " & modelName & vbCr
'MessageBox.Show("In For each oOcc loop")
'wB commented
'myString = myString & oOcc.Name & vbCr
'wB added
'if it is an assembly call GetOccName and put the occurrence name in myString
If (oOcc.DefinitionDocumentType = kAssemblyDocumentObject) Then
               'myString = myString + "In Main " &  GetOccName(oOcc.SubOccurrences, myString)
               'myString = "In Main " &  GetOccName(oOcc.SubOccurrences, myString)
               myString = myString & "SubAssembly " & vbCr
               myString = myString & oOcc.Definition.Document.DisplayName & vbCr
               'MessageBox.Show("In If assembly document myString = " & myString)
               myString = GetOccName(oOcc.SubOccurrences, myString)
'wB added
If (oOcc.DefinitionDocumentType = kPartDocumentObject) Then
               'myString = myString & "Part " & vbCr
'wB commented
'Else If oOcc.Name = NAME Then 'if name is in this list = NAM
'wB commented
'Goto MESSAGE
Next 'occurrence
'wB commented
'Next 'DrawingViews
MESSAGE:
'enter more code here
'my problem is dont show part in sub assembly and if i have a ipn in the page i have a error message?
End Sub
'wB added
Private Function GetOccName(oOccs As ComponentOccurrences, str1 as String) As String
    For Each oOcc In oOccs
     '   MessageBox.Show("In For each loop" & oOcc.Name)
                              If (oOcc.DefinitionDocumentType = kPartDocumentObject) Then ' part
                                             str1 = str1 & oOcc.Definition.Document.DisplayName & vbCr
        ElseIf (oOcc.DefinitionDocumentType = kAssemblyDocumentObject) Then
            str1 = str1 & "SubAssembly " & vbCr
                                  str1 = GetOccName(oOcc.SubOccurrences, str1)
    Next
               'MessageBox.Show(Str1 & vbCr & " Returning from GetOccName")
               Return str1
End Function
Wayne Brill
Message 11 of 32
Thanks again for your time Wayne, it's kind 🙂
your rule work great in selected view, that i want but for all drawing view in sheet, but the same problem if i have a drawing view with ipn inside again
a error message.
Message 12 of 32
wayne.brill
Did the files you attached previously have a drawing view with an ipn inside? If not please provide the files that will allow me to recreate the error you are getting.
Also you can change the rule so it goes through all of the drawing views on the sheet. The rule I initally posted on this thread did that. I simplified the last rule I posted so it just went through the occurrences in the selected drawing view.
Wayne Brill
Message 13 of 32
this is the file!
Message 14 of 32
wayne.brill
Thanks for the .ipn file. I created a view using that file. When I run the rule I get this error:
Error in rule: Rule1, in document: TEST123.idw
Public member 'ComponentDefinition' on type 'PresentationDocument' not found.
This is becuase this line is using the ComponentDefinition property.
The problem is that the variable named oAssembly is not an AssemblyDocument but is a PresentationDocument
A PresentationDocument does not have a ComponentDefinition property. You could add an if statement and have different code run based on the type of document. Here is a rule I have. When you need to figure out how to get Inventor API code to work it really helps to use VBA to test it and get it working. You can then move it over to a rule and make the changes neccessary to get it working as a rule. (very much like VB.NET) Please keep in mind that this is just a quick example and I did not test for every possibility. (I just tested with drawing veiws that use an assembly and a presentation document.
This rule now has an if statement. If it is a presentation document then it assigns to the oAssembly variable using this code:
  oAssembly = oReferencedDoc.ReferencedDocuments(1)
'wB added Sub Main
Sub Main()
               "SLECT VIEW")
'wB commented
'wB added
'wB commented
Dim oReferencedDoc = refDocDesc.ReferencedDocument
Dim oAssembly
If oReferencedDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
    MessageBox.Show("this is an Assembly", "Title")
ElseIf oReferencedDoc.DocumentType = kPresentationDocumentObject Then
     MessageBox.Show("this is a presentation document", "Title")
               ' Return
'wB added
myString = "Top level doc  = " & modelName & vbCr
'wB commented
'wB added
Then
'wB added
'wB commented
'wB commented
'Goto MESSAGE
Next 'occurrence
'wB commented
'Next 'DrawingViews
MESSAGE:
End Sub
'wB added
                                             Dim oDoc2 As DrawingDocument
                                             oDoc2 = ThisDoc.Document
                                             Dim oDrawCrvsEnum2 As DrawingCurvesEnumerator
                                             Dim oDrawView2 = oDoc2.ActiveSheet.DrawingViews(3)
                                             oDrawCrvsEnum2 = oDrawView2.DrawingCurves(oOcc)
                                             MessageBox.Show(oDrawCrvsEnum2.count)
    Next
               Return str1
End Function
Wayne,
Wayne Brill
Message 15 of 32
Hi Wayne 🙂
Dont work with single part now 🙂
it's possible to see all part in sheet, same to your first rule?
Thanks again, it's really appriciate!
Message 16 of 32
wayne.brill
Here is an update to the rule. It has the for each loop to go through all of the drawing views. A MessageBox is displayed for every view showing the name of the top level document. (part, assembly or presentation) It then gathers the names of sub assemblies and parts. I believe this is close to what you need. Please try to make it do what you need if there is something missing.
'wB added Sub Main
Sub Main()
Dim refDocDesc
Dim oReferencedDoc
Dim oAssembly
Dim oPart
Dim ModelName
Dim NAME
'MessageBox.Show("right after for each", "Title")
'modelName = IO.Path.GetFileName(oAssembly.FullFileName)
'MessageBox.Show("FullFileName = " & oAssembly.FullFileName, "Title")
'NAME = Left(modelName, Len (ModelName) -4) & ":1"
NAME = oAssembly.DisplayName ' & ":1"
myString = myString & "Top level Assembly = " & NAME & vbCr
myString = myString & "Top level Presentation doc = " & NAME & vbCr
' Return
ElseIf oReferencedDoc.DocumentType = kPartDocumentObject
oPart = oReferencedDoc
MessageBox.Show("This is a Part document " & oPart.FullFileName, "Title")
'Do something here with the part
' Go to the next DrawingView in the for next loop
Continue For
'wB added
'wB added
Next 'occurrence
Next 'DrawingViews
MESSAGE:
End Sub
'MessageBox.Show("In For each loop" & oOcc.Name)
Next
Return str1
End Function
Wayne
Wayne Brill
Message 17 of 32
Hi Wayne, thanks you very much for all your works and times 🙂
Work great, now i want to add more code if my select view with part in exciste in this list, it's possible?
Message 18 of 32
wayne.brill
I am not sure what you are asking for here.
If you want to get the selected drawing view you could do that. One of the rules in this post had the user select a drawing view. If you don't have them select the drawing view then it would need to be selected before you run the rule.  The code could compare the selected drawing view with the drawing views in the for each loop. You could get a variable with part name and use an if statement to determine if it is in a drawing view.
If this does not help please include the code you have tried that is not working.
Wayne Brill
Message 19 of 32
hi!
I know for the selected drawing view, i want to know, how to add a code in rule who determine if this part selected in view exciste in this show list created by your rule?
Sorry again fro my horrible english, i try 😉
Message 20 of 32
wayne.brill
Here is another rule to try. An edge in a DrawingView needs to be selected. If a edge (DrawingCurveSegment) is not selected it displays a message and returns.
This example gets the display name of the document the selected edge belongs to. It uses name to find out if that part is in one of the other views.
Sub Main()
Dim refDocDesc
Dim oReferencedDoc
Dim oAssembly
Dim oPart
Dim ModelName
Dim NAME
Dim selObj
Dim partNameToTest
'see if there is something selected
If oDoc.SelectSet.Count > 0 Then
'Get the first selected entity
selObj = oDoc.SelectSet(1)
'MessageBox.Show(TypeName(selObj), "Title")
'see if the selected entity is a DrawingCurve
If TypeName(selObj) = "DrawingCurveSegment" Then
'get the name of the file the selected DrawingCurveSegment is in
 Dim oCompDef As ComponentDefinition
  oCompDef = selObj.Parent.ModelGeometry.Parent.ComponentDefinition
  partNameToTest = oCompDef.Document.DisplayName
 ' MessageBox.Show(partNameToTest, "Title")
 Else
 MessageBox.Show("Selected object not an edge in a view", "Title")
 Return
End If ' Select object type
Else
    MessageBox.Show("Select an edge in a view", "Title")
    Return
End If ' SelectSet.Count
myString = myString & "View " & oDrawView.Name & vbCr
'MessageBox.Show("this is an Assembly", "Title")
'MessageBox.Show("this is a presentation document", "Title")
' Return
'MessageBox.Show("This is a Part document " & oPart.FullFileName, "Title")
Continue For
' MessageBox.Show(oDrawCrvsEnum.count)
If oDrawCrvsEnum.Count > 0 Then
'wB added
'MessageBox.Show(myString)
myString = GetOccName(oOcc.SubOccurrences, myString,partNameToTest )
 ' MessageBox.Show(oOcc.Definition.Document.DisplayName)
  If oOcc.Definition.Document.DisplayName = partNameToTest Then
     myString = myString & partNameToTest & " is in this view !!!" & vbCr
 Else
Next 'occurrence
Next 'DrawingViews
End Sub
Private Function GetOccName(oOccs As ComponentOccurrences, str1 as String, partNameToTest As String) As String
      str1 = str1 & partNameToTest & " is in this view !!!" & vbCr
    'MessageBox.Show(partNameToTest & " is in this view ", "Title")
  Else
str1 = GetOccName(oOcc.SubOccurrences, str1, partNameToTest)
Next
Return str1
End Function
Maybe this is close to what you need.
Wayne
Wayne Brill
