Parameter types
Parameter types
oransen
Message 1 of 8
Parameter types
oransen
Should I use get_Units to find out if a Model or User parameter is a double or an integer or...?
Replies (7)
Message 2 of 8
MegaJerk
You would use TypeName.
MessageBox.Show(TypeName(ParameterNameHere))
Example
Dim frank As String
frank = "1222"
MessageBox.Show(TypeName(frank))
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Message 3 of 8
Vladimir.Ananyev
Numeric parameter values internally  are always Double.
(that's why you need to be careful when compare them for equality).
Units property is useful if user parameter contains text.
In this case Parameter.Units property returns "Text".
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 4 of 8
oransen
In your example you are using VB variables. I was thinking of parameters in a parametric model. I don't think your method would work in that case.
Message 5 of 8
oransen
So even integer counts are stored as doubles?
Message 6 of 8
Vladimir.Ananyev
Yes, integers values of numeric parameters are stored as doubles.
You may find out that the e.g. length parameter is "integer" assuming some tolerance:
if abs(x - round(x,6)) < 0.000001 then <x is integer>
Vladimir Ananyev
Message 7 of 8
oransen
Actually suppose I should know if it is integer or double since I probably create the parameter!
Message 8 of 8
Vladimir.Ananyev
Of course we always know if our parameter should be integer or not  Smiley Happy
But we should remember that it is rather dangerous directly compare “integer” parameter with the reference integer value:
       If oParameter.Value = 1 then <do something>
because oParameter.Value could be equal to 1.000000000001
Be careful.
Cheers,
Vladimir Ananyev
