Parameter to have leading and ending zeros
jletcher
Advisor Advisor
Message 1 of 10
jletcher
I have a client that wants the part number to be driven by size with a catch.
Hope I can explain it for all to understand. I have it some what working but need some guidance.
The part number goes like this:
625A3-A01.000M0.500 or 625A3-A10.000M1.000
625A3 = Profile Threaded or unthreaded rod
A= material type A-Mild Steel, B-Ground and polish rod, C-Stainless steel and so on
01.000 is the Length of the part (this is an issue will explain at bottom)
M= thread code  K-no tapping, L-10-32 UNC, M-1/4-20 UNC, N- 5/16-18 and so on
.500= Diameter of rod ( nothing bigger than 9 inches)
Ok I have everything working but the Length the issue with this is the leading and trailing zeros and extra..
If the length is 1/2 inch the number needs to show as 00.5000 if it is 1 inch needs to show as 01.000 if it was 10 inches it needs to show like 10.000.
Now this is the problem I am having if it is 1/2 I get this 0.500 but I need that extra 0 in the front like 00.500.
I am also having issues when the number is 4 inches or a rounded number 10,9,5 no matter if I have the parameter set to show trailing zeros it seems to work and not work so I get 4 and not 4.000 even in this I would have to get ilogic to add a zero to it like 04.000.
How can I get ilogic to look at the number of characters in the Length and if it is less than the what I need add the others.
Hope I explained it for all to understand. If not ask away and I will try to expain more.
Here is what I have been trying but I am failing.
If LENGTH >= Len(5) Then
	Parameter("L_1") = "0" & LENGTH & ".000"
Else
	Parameter("L_1") = LENGTH
iProperties.Value("Project", "Part Number")= "625A3-" & Mat_Code & L_1 & Tap_Code & Rod
Replies (9)
Message 2 of 10
jletcher
I added this to try to get the trailing zeros to show but still no luck.
Parameter("L_1") = "0" & Round(LENGTH,3)
Message 3 of 10
jletcher
Hello, is there any body out there........ Pink floyd Smiley Happy
Message 4 of 10
Curtis_W
Hi jletcher,
Assuming this is being done via ilogic, you can use something along these lines:
iLogicOption DoubleForEquals Off
sL_1 = Format(L_1, "00.000")
sRod = Format(Rod, "00.000")
iProperties.Value("Project", "Part Number") = "625A3-" & Mat_Code & sL_1 & Tap_Code & sRod
see this link for more on the VB Format function:
http://msdn.microsoft.com/en-US/library/59bz1f0h%28v=vs.80%29.aspx
I hope this helps.
Curtis
Message 5 of 10
jletcher
Curtis I swear you are thee MAN.......
Smiley Happy
Thank you so much. I never thought of using the same thing I use in excel..
Message 6 of 10
I have a problem ?
my value is 0,0125 and when is rounding becoming at 0,012 but not true?
the good result for me is 0,013
this is my rule
CODE =  0,0125
CODE2 = Round(CODE,3)
Thamks for your help
Message 7 of 10
adam.nagy
Autodesk Support
Autodesk Support
I'm quite sure that this is because of the underlying .NET behaviour. You can read about that on various sites:
http://stackoverflow.com/questions/977796/why-does-math-round2-5-return-2-instead-of-3-in-c
So you could use the .NET function directly to round away from zero instead of to even:
MsgBox(Math.Round(0.0125, 3, MidpointRounding.AwayFromZero))
This will give you 0.013
Cheers,
Adam Nagy
Autodesk Platform Services
Message 8 of 10
thanks you for your help Adam, i try that 🙂
Message 9 of 10
all the time 0,013 now 😞 with any number???
Message 10 of 10
jdkriek
sergelachance, you might want to start a new thread - I have a feeling you have other conditions in your code.
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
