Global Form Directory Issue
One of my coworkers is having an issue where the Global Forms tab in his iLogic Browser is empty.  When I right click on the empty space in the tab I can "Open Containing Folder" to see the current directory.  How can I set the containing folder (I know the correct directory) to the one it needs to be?
Thanks in advance.
adam.nagy
Autodesk Support
Autodesk Support
The external forms are stored in a subfolder under the "Design Data" folder as Mike says it here: http://forums.autodesk.com/t5/Autodesk-Inventor/Global-Forms-in-network/td-p/3026716
Here is where the "Design Data" folder can be set for a project: http://www.inventortales.com/2010/04/application-options-or-project-folder.html
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
