Parameter strings
Parameter strings
Parameter strings
It would also  be nice if someone could define which strings will work in a parameter equation box.
In other words, do math functions work? Is there a way to make Math functions work?
How about a list of functions that will work, instead of me trying a million different combos to get something to work?
Does anyone check these message boards anymore?
I've been working on a Huge project using Ilogic, Iparts and Iassemblies. It is very frustrating when things seem not to work the way they should and you can't get any help.
---UGH!
Have you looked at the help files?
There is a section on what formulas and equations are supported within parameters
Here is the online page
http://wikihelp.autodesk.com/Inventor/enu/2011/Help/User's_Guide/108DesignOptimization/1642Parameter...
Go down to the References section and expand 'Use formulas and equations'
Tom
Thanks.
I found this in the Inventor API help files by typing in "Enter values in edit boxes", late last night.
Thanks for the help.
