Parameter path cannot be null?
Hi All, I have a iLogic rule for saving drawings (dwg) to a pdf file in a designated folder. Everything worked well until this Monday morning. Now I get the message: Error in rule: Save2PDF, in document: 13006-027 propflens-1.dwg Value cannot be null. Parameter name: path What can I do to make it work again? This weekend a windows7 update has occurred. This is the iLogic Code: '------start of temp i Logic------- First update settings Dim oControlDef as ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("UpdateCopiedModeliPropertiesCmd") oControlDef.Execute2(True) '------end of temp i Logic------- '------start of iLogic------- oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) 'without extension oRevNum = iProperties.Value("Project", "Revision Number") oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oTekNr = iProperties.Value("Custom", "Tekening Nummer") oSubTitle = iProperties.Value("Summary", "Title") oNewFolder = iProperties.Value("Custom", "ExportMap") If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name If oTekNr = "" Then oDataMedium.FileName = oNewFolder & "\" & oFileName & _ " Rev" & oRevNum & ".pdf" Else oDataMedium.FileName = oNewFolder & "\" & oTekNr & "_" & oFileName & _ " Rev" & oRevNum & ".pdf" End If 'Publish document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'MessageBox.Show("De PDF is gemaakt en staat in de volgende map: " & oFolder , "Regel") 'Show in Explorer Shell("explorer.exe " & oNewFolder,vbNormalFocus) '------end of iLogic-------
Why, can't I change this post?
Why don't the menu options and Topic Options don't work? Even the preview doesn't work! I cannot change my first post, It is not very clear. I even cannot delete it... Not so happy with new styling... Looks good, works bad..
adam.nagy
Autodesk Support
Autodesk Support
Hi Danny,
I'm checking with the forum people where to ask/log forum related issues.
Concerning your iLogic code. The problem is that you're checking if the path defined by oFolder exists, but that variable is not set since you are using oNewFolder.
So just change this part of the code from this
End If
to this
If Not System.IO.Directory.Exists(oNewFolder) Then
System.IO.Directory.CreateDirectory(oNewFolder)
End If
One way of avoding this would be if you forced yourself to declare variables - you can do that by adding "Option Explicit" at the top of your code.
Cheers,
Adam Nagy
Autodesk Platform Services
Discussion_Admin
You can edit or delete your post up to 30 minutes or someone replies to what ever comes first
We are aware of several issues and havee fix several of them and are working digently on others check the Community Feedback fourm to see if your's have been listed or post a new issue\comment.
Discussion_Admin
Thanks, I will look into the declaration of the variables!
