Parameter is Incorrect?
Hi all, trying to do some coding, wanting to add a symbol to a sheet using some VB.NET code.
I can create the symbol just fine, but when I try to place the symbol on the sheet at (0,0) I get the error "The parameter is incorrect".
Google has failed me, any suggestions?
Sergio.D.Suárez
Hi, just to discard possibilities. Personally I have had problems in the "promtstrings", for example if I need 4 entries I must specify the number 3, because the array starts counting from zero. You can take the test if you put the promtstrings (0) and it will return a value. I clarify this because if you need 5 tickets and you put the number 5 you are actually specifying 6 entries. I hope you can solve your problem.
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
@Sergio.D.Suárez
Thanks for spending the time to respond. I'm still quite new to programming and what you described, I did not understand. Could you explain again?
Sergio.D.Suárez
Here is an example in ilogic (which is based on VB.net I think).
There are four entries requested. in the code they are marked 3 because it counts from zero.
He does not know the time that I have lost for such a tiny detail !
I attached the file to make it easier to understand.
Execute and observe rule 1.
I hope you can solve your problem. regards
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oSymDef As SketchedSymbolDefinition = oDoc.SketchedSymbolDefinitions.Item("Label - Door/Window")
Dim sPromptStrings(3) As String
sPromptStrings(0) = "Value A"
sPromptStrings(1) = "Value B"
sPromptStrings(2) = "Value C"
sPromptStrings(3) = "Value D"
Dim oPosition As Point2d =  ThisApplication.TransientGeometry.CreatePoint2d(10,15)
Dim oSymbol As SketchedSymbol
oSymbol = oSheet.SketchedSymbols.Add(oSymDef, oPosition,0,1,sPromptStrings)
Mechanical Designer
Aah. I understand what you were explaining. The code that I'm trying to duplicate is from an example inside the Inventor API help file. After looking at your last post, I figured out what I was missing:
I had failed to put the "(0)" bits after my promptstring definition.
Since I was duplicating the example, I don't understand why Promptstring is even used. Tooltips and definitions inside Visual Studio are not really helping. Could you explain?
