Need Help with opening autocad from inventor VBA
I used to have a code that would export a drawing from inventor to autocad then open the newly created drawing in autocad.  So i have recreated the export dwg but unable to remember or figure out how to open autocad mechanical.  When I look, I have no reference options for autocad object.  Any suggestions?
Mark.Lancaster
@Anonymous
Use the Inventor Customization forum for this https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will have the moderator relocate your posting there to best suit your needs.
Mark Lancaster
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that suggestion in the below link may be helpful.
https://www.eng-tips.com/viewthread.cfm?qid=245944
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bozidarJES3S
