Pack and go using ilogic save all documents
aronmatheus
Message 1 of 8
aronmatheus
I'm using this code, but I would send the folder idw too. Because this code save as ipt and iam.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.",vbOK, "WRONG DOCUMENT TYPE")
Return
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oFileDlg As Inventor.FileDialog = Nothing
ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
oFileDlg.FileName = ThisDoc.FileName(False)
oFileDlg.DialogTitle = "Specify New Name & Location For Copied Assembly"
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowSave
If Err.Number <> 0 Then
MsgBox("No File Saved.", vbOKOnly, "DIALOG CANCELED")
ElseIf oFileDlg.FileName <> "" Then
oNewFileName = oFileDlg.FileName
oADoc.SaveAs(oNewFileName, False)
oADoc = Nothing
InventorVb.DocumentUpdate()
oADoc = ThisApplication.ActiveDocument
Dim oLast3Chars As String
For Each oRefDoc As Document In oADoc.AllReferencedDocuments
ThisApplication.Documents.Open(oRefDoc.FullFileName,False)
oLast3Chars = Left(Right(oRefDoc.FullFileName, 7), 3)
If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oRefPDoc As PartDocument = oRefDoc
Dim oRefPDef As PartComponentDefinition = oRefPDoc.ComponentDefinition
If oRefPDef.IsContentMember = False Then
oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".ipt", True)
ElseIf oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".iam", True)
oRefDoc.Close
Next
Dim oOccDoc As Document
Dim oOccNewFileName As String
For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences
oOccDoc = oOcc.Definition.Document
oLast3Chars = Left(Right(oOccDoc.FullFileName, 7), 3)
If oOccDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oOccPDef As PartComponentDefinition = oOcc.Definition
If oOccPDef.IsContentMember = False Then
oOccNewFileName = Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".ipt"
ElseIf oOccDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
oOccNewFileName = Left(oADoc.FullFileName,Len(oADoc.FullFileName)-4) & oLast3Chars & ".iam"
oOcc.Replace(oOccNewFileName, True)
Next
Replies (7)
Message 2 of 8
FINET_Laurent
This rule is duplicating assemblies. Why not copying the folder instead?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 8
aronmatheus
Hi @FINET_Laurent, because when I finish the project the I will change the name of the parts.
Message 4 of 8
FINET_Laurent
Can you explain the workflow in more than one line please ? I'm not sure I understand.
FINET L.
Message 5 of 8
aronmatheus
Hi @FINET_Laurent , I want to do the same in this picture because I'm using this macro. Now I would like to save the idw file too.
Message 6 of 8
A.Acheson
@aronmatheus
Here is a standalone function you could integrate in or alternatively just slot in the key snippets at the location you want.
It might be nice to keep it separate as these can get confusing. You can remove the update iproperty command if not needed,“UpdateCopiedModeliPropertiesCmd“
https://forums.autodesk.com/t5/inventor-customization/ilogic-replace-reference-file-in-drawing-when-...
Function DrawingReplace(OldLoc As String, newname As String)
Dim OldName As String = Left(OldLoc, Len(OldLoc) -3) & "dwg"
Dim DrawDoc As DrawingDocument = ThisApplication.Documents.Open(OldName, False)
Dim DrawingName As String = (Left(newname, Len(newname) -3) & "dwg")
If Dir((Left(newname, Len(newname) -3) & "dwg")) = "" Then
DrawDoc.SaveAs(DrawingName, False)
Dim oFD As FileDescriptor
 oFD = DrawDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
  oFD.ReplaceReference(newname)
Dim oControlDef As ControlDefinition  = ThisApplication.CommandManager.ControlDefinitions.Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute
DrawDoc.Update()
DrawDoc.Save
DrawDoc.Close
End Function
Regards
Alan
Message 7 of 8
Aron.Carvalho
Hi @A.Acheson, I don't understand your ruler, where can I put this function?
Message 8 of 8
A.Acheson
You would call it just like a sub. Off course this doesn't match above terminology so is more for the principal of what needs to be achieved.  This is not tested.
Sub Main
Dim OldLoc As String
OldLoc = "C:\Users\1234.dwg
Dim newname As String
newname = "12345"
'*******************Insert Message 1 rule here copying of  rules here etc********************
'Call Save As Drawing
Call DrawingReplace(OldLoc , newname )
End Sub
Regards
Alan
