ilogic replace reference file in drawing when opened invisible
Hi all,
I have a piece of code that should replace a file reference in a drawing.
This is done by first looking if a drawing exists, and when it does i save the drawing under a different name.
Next i want to replace the file reference to make the drawing represent another model.
The problem is when i open a drawing invisible the reference is not replaced.
When the the drawing is opened visible the reference replace does work.
the problem is that when i open a drawing visible it has to load all the graphics and i get some pop-up messages if i want to modify the file and i don't want any input when the process is running.
I checked all the paths and everything is running as it should.
Function DrawingReplace(OldLoc As String, newname As String)
Dim OldName As String = Left(OldLoc, Len(OldLoc) -3) & "dwg"
Dim DrawDoc As DrawingDocument = ThisApplication.Documents.Open(OldName, False)
Dim DrawingName As String = (Left(newname, Len(newname) -3) & "dwg")
If Dir((Left(newname, Len(newname) -3) & "dwg")) = "" Then
DrawDoc.SaveAs(DrawingName, False)
Dim oFD As FileDescriptor
 oFD = DrawDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
  oFD.ReplaceReference(newname)
Dim oControlDef As ControlDefinition  = ThisApplication.CommandManager.ControlDefinitions.Item("UpdateCopiedModeliPropertiesCmd")
oControlDef.Execute
 DrawDoc.Update()
DrawDoc.Close
End Function
Kind regards,
Geert
omartin
Hey Geert, seems like it should be working only thing is, after you do the replace ref I don't see you saving the drawing before close.
Was my reply Helpful ? send a Kudos or accept as solution
Haha, thank you!
could not imagine the solution would be this simple.
