check export parameter box from main assembly to all parts
Message 1 of 9
I want to check the export parameter box in all part of my weldment frame assembly. I have square tube of different length and same size. want to export depth, width, and thickness parameter for all tube in one operation and after that I also want to change custom parameter properties format of all parts. I want to do it from top assembly without opening any part.
Is there any way to do it? I can't open each part every time and export parameter and change custom properties for all the parts. It will take too much time for larger assemblies.
Thanks in advance.
Replies (8)
Message 2 of 9
HideoYamada
Hello pds9,
Open weld doc and run this vba code.
The parameters named "G_W", "G_H" or "G_T" in all sub part will be checked for export.
Option Explicit
Public Sub SetExportAllSubPart()
    Dim ParamNamesToExport() As Variant
    ParamNamesToExport = Array("G_W", "G_H", "G_T")
    Dim thisDoc As AssemblyDocument
    Set thisDoc = ThisApplication.ActiveEditDocument
    Dim occ As ComponentOccurrence
    For Each occ In thisDoc.ComponentDefinition.Occurrences
        If TypeOf occ.Definition Is PartComponentDefinition Then
            Dim partCompDef As PartComponentDefinition
            Set partCompDef = occ.Definition
            Dim param As Parameter
            For Each param In partCompDef.Parameters
                SetExport param, ParamNamesToExport
            Next
    Next
End Sub
Private Sub SetExport(param As Parameter, ByRef names() As Variant)
    Dim name As Variant
    For Each name In names
        If param.name = name And param.ParameterType = kUserParameter And param.ExposedAsProperty = False Then
            param.ExposedAsProperty = True
            Exit For
    Next
End Sub
I hope this code will help you.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 3 of 9
Thanks Hideo for reply,
But after adding code inventor shows Sub Main error. Attached is the error image.
Can you please show me how to fix this error because I am new to inventor iLogic, so do not know much about it.
Thank You.
Message 4 of 9
HideoYamada
Hello pds9,
Are you run with iLogic?
If so, try run the code with VBA.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 5 of 9
Thanks Hideo the code works in VBA.
Can you please add additional lines to this code for change custom parameter format. Like on and off trailing and leading zeros and some like that.
For me I want to change the trailing zeros check mark off for all parameters. So, I only get integer dimension values when it is applicable.
Thank you for this code.
Message 6 of 9
HideoYamada
Hello pds9,
Replace Sub SetExport() with this :
    Dim name As Variant
            param.CustomPropertyFormat.ShowUnitsString = True
            param.CustomPropertyFormat.ShowLeadingZeros = True
            param.CustomPropertyFormat.ShowTrailingZeros = False
            Exit For
    Next
End Sub
Does this code work fine?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
Message 7 of 9
Hi Hideo,
Code now works fine with everything. Problem solved.
Thank you for your support.
Message 8 of 9
jpdemers
I'm new to Ilogic and I'm trying to use this vba code to export the "Thickness" FX parameter but it doesn't work.
Well, I don't really know how to do it.
I'm not sure I use VBA the right way.
Can you help me out?
Thanks.
Message 9 of 9
HideoYamada
Thanks.
Try this rule :
option Explicit on
Imports System.Collections.Generic
Public Sub Main
	Dim paramNamesToExport = New List(Of String) From {"Thickness"}
	For Each occ As ComponentOccurrence In ThisDoc.Document.ComponentDefinition.Occurrences
			Dim partCompDef As PartComponentDefinition = occ.Definition
				SetExport(param, paramNamesToExport)
			Next param
	Next occ
End Sub
Private Sub SetExport(param As Parameter, names As List(Of String))
		If param.Name = name And param.ParameterType = ParameterTypeEnum.kUserParameter And param.ExposedAsProperty = False Then
'			MessageBox.Show(name)
			Exit For
	Next name
End Sub
Freeradical
 Hideo Yamada
