Delete all dimensions on a drawing with ilogic
Good Day,
Does anyone know how to delete all dimensions on a drawing with ilogic/api?
I would like to run a rule that deletes all dimensions on a drawing when loaded, then I want to run another rule that populates the drawing with new dimensions referenced from work points on the model.
I am able to add new dimensions, but would like to know how to delete all existing dimensions with a rule.
Thanks 🙂
AdamAG99T
This bit of code should accomplish what you want. It will delete every drawing dimension on the active sheet. I also added a bit of code to make the entire operation a single undo operation, as it would add each dimension being deleted as it's own entry otherwise.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oDim As DrawingDimension
Dim oTrans As Transaction
oTrans = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument,"Delete")
For Each oDim In oSheet.DrawingDimensions
	oDim.Delete
Next
oTrans.End
Thank You.
Worked like a charm!
Ritesh.Gurao
Hi, Could you share the code to add dimensions in drawing
