Override/remove external rules from all parts in assy
Geveke
Geveke
I have an assembly with approx. 2500 parts in it (got it from external supplier).
If i want to save the assy, it triggers an event trigger to a -non existent external rule- on all parts.
As a result some 2500 error messages will appear; because all parts want to run the -non existing- external rule.
Is there a way to override/remove these event triggers all at once?
With a iLogic rule? VBA?
And if so, what should the code look like?
Thanks in advance.
DRoam
I believe the iLogic Code Injector tool has a "Delete all rules" button that also removes all triggers. You could try that. But the easiest thing would be to just create a blank external rule with the same name as the one it's expecting. Or, you could just unload the iLogic add-in while working with these files to prevent any iLogic from being triggered at all.
Geveke
Hi, the code injector works great!!
Thx. for the reply.
