Orientated Minimum Rangebox for Solid Body Faceshell
william
Message 1 of 11
william
Hello
I have a multi body part with a single solid representing multiple timber rails.
What I would like to be able to do is analyse the solid body that represents the rails, and calculate the length/width/thickness for each rail.
The SurfaceBody.OrientedMinimumRangeBox Property works fine for the whole solid, but I would need to do the same to the faceshells belonging to the solid body.
The code that I have so far works with the x,y,z co-ordinates of the faceshell, but I would like to know how to get the correct dimensions for a faceshell that is not aligned to the x,y,z axis.
Part File attached, with rules inside.
Any ideas?
Threads that I have referenced for the code are:
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/faceshell-orientedrangebox/m-p/10472442
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/getting-accurate-rangebox-xyz-values/m-...
Code Snippet 1 (Faceshell Rangebox)
doc = ThisDoc.Document
oDef = doc.ComponentDefinition
Dim oSB As SurfaceBody
For Each oSB In oDef.SurfaceBodies
	If oSB.Name.Contains("REF_RAILS") Then
			For Each fs As FaceShell In oSB.FaceShells
				If fs.IsVoid Then Continue For
				Dim DeltaX, DeltaY, DeltaZ As Double
				Dim fsBox As Box = fs.RangeBox
				DeltaX = fsBox.MaxPoint.X - fsBox.MinPoint.X
				DeltaY = fsBox.MaxPoint.Y - fsBox.MinPoint.Y
				DeltaZ = fsBox.MaxPoint.Z - fsBox.MinPoint.Z
				' Convert lengths to document's length units.
				Dim uom As UnitsOfMeasure = doc.UnitsOfMeasure
				DeltaX = uom.ConvertUnits(DeltaX, "cm", uom.LengthUnits)
				DeltaY = uom.ConvertUnits(DeltaY, "cm", uom.LengthUnits)
				DeltaZ = uom.ConvertUnits(DeltaZ, "cm", uom.LengthUnits)
				' Sort lengths from smallest to largest.
				Dim lengths As New List(Of Double) From {DeltaX, DeltaY, DeltaZ }
				lengths.Sort
				Dim minLength As Double = lengths(2)
				Dim midLength As Double = lengths(1)
				Dim maxLength As Double = lengths(0)
				' Display minimum rangebox size.
				MessageBox.Show("Rangebox Size: " &
					minLength.ToString("#.###") & " x " & midLength.ToString("#.###") & " x " & maxLength.ToString("#.###"),
					oSB.Name, MessageBoxButtons.OK, MessageBoxIcon.Information)
			Next
Next
Code Snippet 2 (Surface Body Orientated Minimum Rangebox)
' Get surface body to measure
	Dim minBox As OrientedBox = oSB.OrientedMinimumRangeBox
	' Get length of each side of mininum range box.
	Dim dir1 As Double = minBox.DirectionOne.Length
	Dim dir2 As Double = minBox.DirectionTwo.Length
	Dim dir3 As Double = minBox.DirectionThree.Length
	dir1 = uom.ConvertUnits(dir1, "cm", uom.LengthUnits)
	dir2 = uom.ConvertUnits(dir2, "cm", uom.LengthUnits)
	dir3 = uom.ConvertUnits(dir3, "cm", uom.LengthUnits)
	Dim lengths As New List(Of Double) From {dir1, dir2, dir3 }
	lengths.Sort
	Dim minLength As Double = lengths(0)
	Dim maxLength As Double = lengths(2)
	MessageBox.Show(" Oriented Minimum Rangebox Size: " &
Next
Replies (10)
Message 2 of 11
william
@BrianEkins
You would know if this if it is possible or not. Any suggestions?
Message 3 of 11
josiah.fordCEEGJ
@william I have an iLogic Rule that is halfway there and creates Transient BReps that represent a single faceshell, and uses OrientedMinimumRangeBox to measure that before spitting out the sizes into the solid body name. Below is some of the code that I have done (with some company specific bits stripped out, so it wouldnt run as is). If you ran a For Next Loop that went through all the faceshells in the solid and wrote the data out somewhere that could potentially work for what you need. The oTransSolids.FaceShells sometimes like to error which is why there's a try catch around it. Hopefully this gives a direction somewhat.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
oNamer = "Process name"
Dim UNDO As Transaction
UNDO = ThisApplication.TransactionManager.StartTransaction(oPartDoc, oNamer)
Dim oCompDef As ComponentDefinition
oCompDef = ThisDoc.Document.ComponentDefinition
i = 0
For Each SurfaceBody In oCompDef.SurfaceBodies
Dim oBody As SurfaceBody
Dim oTransBRep As TransientBRep
oTransBRep = ThisApplication.TransientBRep
Dim oTransSolid As SurfaceBody
Dim oTransLump As FaceShell
i = i + 1
oBody = oCompDef.SurfaceBodies.Item(i)
oLumpsCount = oBody.FaceShells.Count
	oTransSolid = oTransBRep.Copy(oBody)
	Try
	oTransFaces = oTransSolid.FaceShells
	Catch
End Try
Try
	oTransLump = oTransFaces.Item(1)
	Dim facesToDelete As ObjectCollection
	facesToDelete = ThisApplication.TransientObjects.CreateFaceCollection
	Dim fc As Face
		For Each fc In oTransLump.Faces
		Call facesToDelete.Add(fc)
		Next
	oTransBRep.DeleteFaces(facesToDelete, False)
	facesToDelete.Clear
	oBox = oTransSolid.OrientedMinimumRangeBox
	oX = (Round(oBox.DirectionOne.Length, 2))*10
	oY = (Round(oBox.DirectionTwo.Length, 2))*10
	oZ = (Round(oBox.DirectionThree.Length, 2)) * 10
	oTransSolid.Delete
	ooName = "___" & oLumpsCount.ToString & "x" & "[[" & oX.ToString & "mm x " & oY.ToString & "mm x " & oZ.ToString & "mm]]"
	oBody.Name = oBody.Name & ooName
Catch
End Try
Next
UNDO.End
Message 4 of 11
J-Camper
This is an example of what I ended up doing in order to fake the OrientedRangeBox for Faceshells:
Sub Main
	Dim pDoc As PartDocument = TryCast(ThisDoc.Document, PartDocument)
	If IsNothing(pDoc) Then Exit Sub
	Dim PickBody As SurfaceBody = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select a Body")
	If IsNothing(PickBody) Then Exit Sub ' If nothing gets selected then we're done
	Dim BodyDescription As String = BuildDescription(pDoc.ComponentDefinition, PickBody)
	Logger.Trace(BodyDescription)
End Sub
Function BuildDescription(pDef As PartComponentDefinition, oSolid As SurfaceBody) As String
	Dim Result As String = Nothing
	Dim BoxCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	If oSolid.FaceShells.Count > 1
		Logger.Trace("Multi body: " & oSolid.FaceShells.Count)
		For Each fs As FaceShell In oSolid.FaceShells
			'Define Objects to create transient copy
			Dim sbDef As SurfaceBodyDefinition = ThisApplication.TransientBRep.CreateSurfaceBodyDefinition
			Dim lumpDef As LumpDefinition = sbDef.LumpDefinitions.Add()
			Dim fsDef As FaceShellDefinition = lumpDef.FaceShellDefinitions.Add()
			'Start to fill Definition
			For Each f As Face In fs.Faces
				Dim fDef As FaceDefinition = fsDef.FaceDefinitions.Add(f.Geometry, f.IsParamReversed)
				Dim elDef As EdgeLoopDefinition = fDef.EdgeLoopDefinitions.Add()
				For Each ed As Edge In f.EdgeLoops.Item(1).Edges
					elDef.EdgeUseDefinitions.Add(sbDef.EdgeDefinitions.Add(sbDef.VertexDefinitions.Add(ed.StartVertex.Point), sbDef.VertexDefinitions.Add(ed.StopVertex.Point), ed.Geometry), ed.IsParamReversed)
				Next
			Next
			'Body creation
			Dim oErrors As NameValueMap
			Dim TransBody As SurfaceBody = sbDef.CreateTransientSurfaceBody(oErrors)
			BoxCollection.Add(TransBody.OrientedMinimumRangeBox)
		Next
	Else If oSolid.FaceShells.Count = 1
		Logger.Trace("Single")
		BoxCollection.Add(oSolid.OrientedMinimumRangeBox)
	For Each ItemRangeBox As OrientedBox In BoxCollection
		Dim AddString As String = FormulateString(ItemRangeBox.DirectionOne.Length, ItemRangeBox.DirectionTwo.Length, ItemRangeBox.DirectionThree.Length)
		Result += AddString
	Next
	Return Result
End Function
Function FormulateString(DoubleX As Double, DoubleY As Double, DoubleZ As Double) As String
	'Logger.Trace("Formulating")
	Dim Length, Width, Thickness As Double
	Dim inchOutput As Double = 2.54
	Dim inc As Double = 1/64
	Dim dec As Integer = 9
	If DoubleX >= DoubleY And DoubleX >= DoubleZ
		Length = Math.Round(Math.Round((DoubleX / inchOutput),dec)/inc)*inc
		If DoubleY >= DoubleZ
			Width = Math.Round(Math.Round((DoubleY / inchOutput),dec)/inc)*inc
			Thickness = Math.Round(Math.Round((DoubleZ / inchOutput),dec)/inc)*inc
		Else
			Width = Math.Round(Math.Round((DoubleZ / inchOutput),dec)/inc)*inc
			Thickness = Math.Round(Math.Round((DoubleY / inchOutput),dec)/inc)*inc
	Else If DoubleY >= DoubleX And DoubleY >= DoubleZ
		Length = Math.Round(Math.Round((DoubleY / inchOutput),dec)/inc)*inc
		If DoubleX >= DoubleZ
			Width = Math.Round(Math.Round((DoubleX / inchOutput),dec)/inc)*inc
		Else
			Thickness = Math.Round(Math.Round((DoubleX / inchOutput),dec)/inc)*inc
	Else
		Length = Math.Round(Math.Round((DoubleZ / inchOutput),dec)/inc)*inc
		Else
	Result = "(1) @ " & Length.ToString & """ x " & Width.ToString & """ x " & Thickness.ToString & ""","
	Return Result
End Function
 The key was learning how to write existing faceshell data out for the FaceShellDefinition.
Let me know if you have any questions.
Message 5 of 11
Stakin
it is great to solve。wanderful
Message 6 of 11
william
Hello @josiah.fordCEEGJ  & @J-Camper
Thanks for your posts. I havent had a chance to test them yet, but fully intend to do so once I get a spare time from production demands.
Looks like I should be able to get it to work with what youve shared.
Message 7 of 11
william
Thank you. Modified code works nicely. See below/attached:
i = 0
	i = i + 1
	Try
		k = 1
		For j = 0 To oLumpsCount - 1
			oTransLump = oTransFaces.Item(k)
			Dim fc As Face
				Next
			facesToDelete.Clear
			oTransSolid.Delete
			Dim dir1 As Double = Round(oBox.DirectionOne.Length,2)
			Dim dir2 As Double = Round(oBox.DirectionTwo.Length,2)
			Dim dir3 As Double = Round(oBox.DirectionThree.Length,2)
			lengths.Sort
			ooName = oBody.Name & " - Faceshell " & k & " : " & maxLength.ToString & "mm x " & midLength.ToString & "mm x " & minLength.ToString & "mm"
			MessageBox.Show(ooName, "Title")
			k = k + 1
		Next
	Catch
	End Try
Next
The next step for me is to put that into an assembly, to run on a part file existing in assembly, and create a virtual component with the iproperties matching the length/width/thickness of the faceshell.
Message 8 of 11
william
Ok I have made some progress with putting this into an assembly.
I am a bit stuck though, it gives errors in various places.
I get the messages with the correct number of faceshells, but then this error on the last component occurrence.
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.SurfaceBody.get_FaceShells()
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Also it is not getting the correct quantities on the bom.
@josiah.fordCEEGJ & @J-Camper  -any ideas?
The code is pretty muddly, but hopefully the intent is clear enough.
Files attached. Hopefully this will be useful to someone else also.
'Rev 0 - 211012 - WI - Initial Issue
'Notes:
'Solid body names must be named with the following method: REF_RAIL_ <insert solid body identifier here>
'The use of underscore for the seperator in the solid body name must be used.
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("This rule can only be run in an assembly environment" & vbNewLine & "The rule will exit...", "Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
    Return
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
Dim oAsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oOccs = oAsmCompDef.Occurrences
Dim MyArrayList As New ArrayList
Dim MyArrayQTY As New ArrayList
For Each oOcc In oAsmCompDef.Occurrences
	If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
		If oOcc.Name.Contains("REF_RAIL") Then
			oOcc.Delete
Next
	Else
		Dim oCompDef As PartComponentDefinition = oOcc.Definition
		oDoc = oOcc.Definition.Document
		i = 0
			i = i + 1
			If oBody.Name.Contains("REF_RAIL") Then
					strParentDescription = iProperties.Value(oOcc.Name, "Project", "Description")
					strParentName = oDoc.FullFileName
					strSBName = oBody.Name
					strSBNameArray = strSBName.Split("_")
						Try
							strSolidBodyIdentifier = strSBNameArray(2)
						Catch
							strSolidBodyIdentifier = ""
						End Try
				MessageBox.Show(oBody.Name & " = " & oLumpsCount & " Faceshells","Error Checking")
				'Try
					k = 1
					If oLumpsCount <= 1 Then
						Counter = 0
					Else
						Counter = oLumpsCount - 1
					For j = 0 To Counter
							oBox = oBody.OrientedMinimumRangeBox
						Else
							Dim fc As Face
								Next
							facesToDelete.Clear
							oTransSolid.Delete
						lengths.Sort
						strDimensions = midLength.ToString & " X " & minLength.ToString & " - " & maxLength.ToString
						strArrayString = strDimensions & ";" & strParentDescription & ";" & strParentName & ";" & strSolidBodyIdentifier
						MyArrayList.Add(strArrayString)
						MyArrayQTY.Add(1)
						k = k + 1
					Next
				'Catch
				'End Try
		Next
Next
''Error Checking code - to see what the array values are
'oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) & ".txt")
'For i = 0 To MyArrayList.Count - 1
'	oWrite.WriteLine(MyArrayList.Item(i))
'Next
'oWrite.Close()
'ThisDoc.Launch(ThisDoc.PathAndFileName(False) & ".txt")
'Searching for duplicate entries in the array and removing them, also adding the qty's together for duplicates
Try
		ArraySearchItem = MyArrayList.Item(i)
		For j = 0 To MyArrayList.Count - 1
			Try
				If ArraySearchItem <> MyArrayList.Item(j) Then
				Else
					If i = j Then
						'Ignore
					Else
						MyArrayList.RemoveAt(j)
						MyArrayQTY(i) = MyArrayQTY(i) + MyArrayQTY(j)
						MyArrayQTY.RemoveAt(j)
'						MessageBox.Show("Duplicate found: " & _
'						vbNewLine & "MyArrayList.Item(" & i & ") = " & ArraySearchItem & _
'						vbNewLine & "MyArrayList.Item(" & j & ") = " & MyArrayList.Item(j) & _
'						vbNewLine & "MyArrayQTY(" & i & ") = " & MyArrayQTY(i), "Title")
			Catch
			End Try
		Next
	Catch
	End Try
Next
'MessageBox.Show(MyArrayList.Count)
'For i = 0 To MyArrayList.Count -1
'	MessageBox.Show(MyArrayList.Item(i) & vbNewLine & MyArrayQTY.Item(i))
'Next
	strSBNameArray = MyArrayList.Item(i).Split(";")
	strDimensions = strSBNameArray(0)
	strParentDescription = strSBNameArray(1)
	strParentName = strSBNameArray(2)
	strSolidBodyIdentifier = strSBNameArray(3)
	oOccVirt = oAsm.ComponentDefinition.Occurrences.AddVirtual("REF_RAIL " & i, oMatrix)
	strOccName = oOccVirt.Name
	iProperties.Value(strOccName, "Project", "Part Number") = "REF_RAIL " & i
	iProperties.Value(strOccName, "Project", "Stock Number") = strDimensions
	iProperties.Value(strOccName, "Project", "Description") = strSolidBodyIdentifier
	iProperties.Value(strOccName, "Custom", "Parent") = strParentDescription
	ThisBOM.OverrideQuantity("Model Data","REF_RAIL " & i,MyArrayQTY.Item(i))
Next
MyArrayList.Clear
MyArrayQTY.Clear
Message 9 of 11
josiah.fordCEEGJ
@william I get the same error, even when just running in a single multi-body part, by all accounts it seems to fail on a selection of random solids, which changes every run. So in my case it's the line "
 every time, this is the exact point where it fails, its like it can't find the faceshell, or is getting confused somewhere. So I wrote a try catch around a couple different parts which identifies the ones that error, leaves them alone except for marking them and then runs a seperate rule that goes through and targets only those solids...
The full stable (but still quite messy, I'm very much an amatuer) code is below.
oNamer = "MultiMeasure"
i = 0
i = i + 1
If Right(oBody.Name, 2) = "]]"
oBody.Name = Left(oBody.Name, oBody.Name.IndexOf("___"))
If Left(oBody.Name, 1) = "'" Then
	If oLumpsCount < 2 Then
	ooName = "___1x[[" & oX.ToString & "mm x " & oY.ToString & "mm x " & oZ.ToString & "mm]]"
	Else
	Try
	Catch
	ooName = "___" & oLumpsCount.ToString & "x" & "[[ERROR]]"
End Try
Try
	Dim fc As Face
		Next
	facesToDelete.Clear
	oTransSolid.Delete
Catch
End Try
Else If Left(oBody.Name, 1) = "#"
ooName = "___[[x" & oLumpsCount.ToString & "]]"
Next
iLogicVb.RunExternalRule("Multi-Measure_ERRORS")
UNDO.End
and once that names the bodies it couldn't do on that run I run the slightly modified "Multi-Measure_ERRORS" code below.
oNamer = "Error-Catch"
i = 0
i = i + 1
If Right(oBody.Name, 9) = "[[ERROR]]"
	Try
	Catch
End Try
Try
	Dim fc As Face
		Next
	facesToDelete.Clear
	oTransSolid.Delete
Catch
End Try
Next
UNDO.End
and that usually cleans up all the ones it couldn't on the first run. As I said it seems to randomly error and so this method has been working perfectly for me on a few very different models. There is definitely a way to combine the codes together to run as one, but I haven't had the chance to colate them yet.
Hope this helps! I only figured this out fully and got it stable last week!
Message 10 of 11
J-Camper
I was getting issues with some bodies, I think the combine cut feature was a problem i identified, when I was still trying to use the delete face method.  The transient body creation method i posted earlier is much more robust then the delete face method.  I'm currently using it in my own custom rules.
Here is a bit of an extension to the code i posted before, where it will run in part or assembly:
Sub Main
	Dim aDoc As AssemblyDocument = TryCast(ThisApplication.ActiveDocument, AssemblyDocument)
	If Not IsNothing(aDoc) Then Call AssemblyEnvironment(aDoc)
	If Not IsNothing(pDoc) Then Call PartEnvironment(pDoc)
End Sub
Sub AssemblyEnvironment(oDoc As AssemblyDocument)
Selection:
	Dim PickCO As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select Part with body to extract")
	If IsNothing(PickCO) Then Exit Sub ' If nothing gets selected then we're done
	If PickCO.Definition.Document.DocumentType <> kPartDocumentObject Then If MessageBox.Show("Selected Occurence is not a part document.  Would you like to pick a different occurrence?", "Re-Pick?", MessageBoxButtons.YesNo) = vbYes Then GoTo Selection Else Exit Sub
	Dim pDef As PartComponentDefinition = PickCO.Definition
	Dim solidList As New List(Of String)
	Dim Correspondence As New List (Of Integer)
	For Each b As SurfaceBody In pDef.SurfaceBodies
		solidList.Add(b.Name & ":" & solidList.Count+1)
	Next
	If solidList.Count < 1 Then Logger.Trace("No Solids") : Exit Sub
	Dim pickedName As String = InputListBox("Select a Body to extract for Purchase List", solidList, solidList.Item(0), Title := "Solid Body Selection", ListName := "Available Bodies")
	If IsNothing(pickedName) Then Logger.Trace("No Selection") : Exit Sub
	Dim bodyIndex As Integer = CInt(Right(pickedName, pickedName.Length - pickedName.LastIndexOf(":") -1))
	Dim PickedSolid As SurfaceBody = pDef.SurfaceBodies.Item(bodyIndex)
	Dim BodyDescription As String = BuildDescription(pDef, PickedSolid)
End Sub
Sub PartEnvironment(oDoc As PartDocument)
	Dim BodyDescription As String = BuildDescription(oDoc.ComponentDefinition, PickBody)
End Sub
				Next
			Next
			'Body creation
		Next
		Result += AddString
	Next
	Return Result
End Function
		Else
		Else
	Else
		Else
	Return Result
End Function
The occurrence & body selection methods can be changed to a loop if desired and I'm currently just outputting a single string with the dimensions of each faceshell.  You will have to implement your actual reporting method, but it should be pretty easy.
If you have any questions, please let me know.
Message 11 of 11
william
Thanks.
Working well. Should save a lot of time, not having to manually detail cutlists.
Your pointers on the transient body creation method removed the instability with the delete face method.
Code below.
'Notes:
    Return
Dim MyArrayDeleteList As New ArrayList
			oOcc.Delete
Next
	Else
		If oOcc.BOMStructure = kReferenceBOMStructure
			'Ignore parts with Bom set to reference
		Else
			i = 0
				i = i + 1
						Try
						Catch
						End Try
								For Each fs As FaceShell In oBody.FaceShells
												Next
										Next
								Next
							Dim dir1 As Double = Round(ItemRangeBox.DirectionOne.Length,2)
							Dim dir2 As Double = Round(ItemRangeBox.DirectionTwo.Length,2)
							Dim dir3 As Double = Round(ItemRangeBox.DirectionThree.Length,2)
							lengths.Sort
							MyArrayQTY.Add(1)
						Next
			Next
Next
MyArrayList.Sort()
		If i = 0
		Else
			If MyArrayList(i) = MyArrayList(i - 1) Then
				MyArrayDeleteList.Add(i-1)
				MyArrayQTY(i) = MyArrayQTY(i) + MyArrayQTY(i-1)
			Else
	Next
		For i = 0 To MyArrayDeleteList.Count - 1
			MyArrayList.Item(MyArrayDeleteList(i)) = "Delete"
			MyArrayQTY.Item(MyArrayDeleteList(i)) = "Delete"
		Next
			For i = (MyArrayList.Count - 1) To 0 Step -1
				If MyArrayList(i) = "Delete" Then
					MyArrayList.RemoveAt(i)
					MyArrayQTY.RemoveAt(i)
			Next
'	oWrite.WriteLine(MyArrayQTY(i) & " X " & MyArrayList.Item(i))
'Next
'oWrite.Close()
Next
MyArrayList.Clear
MyArrayQTY.Clear
