iLogic Qty rule not working on assemblies/parts with model states
We have been using an ilogic rule I originally found on this forum, I just tweaked it slightly to suit our needs. With the introduction of the model states though it skips these files. I have been adding in different snippets of code that I've found on here but nothing has worked so far. I've just linked this field to our titleblock as well so its a bit more urgent and can't really wait for me to work it out myself. I generally find all my answers on here but with model states being so new there doesn't seem to be many posts.
When this runs there aren't any errors but any parts/assemblies with model states aren't updated. I assumed its possible to write to these parts as they're available for editing in the BOM.
Any help would be greatly appreciated!
Here's the code we are currently using:
Sub Main () 'Check to see if this document is an assembly. oDoc = ThisApplication.ActiveDocument If oDoc.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule can only be run in an Assembly file - exiting rule...", "GDI iLogic") Return End If 'If iProperties.Value("Project", "Project")="" ' oProj = InputBox("Change Project Name", "Project Name", iProperties.Value("Project", "Project")) ' iProperties.Value("Project", "Project")=oProj 'End If 'get the project number of this assembly and use it to build the name of a custom property, i.e. "4100_QTY" customPropertyName = "Total Qty" oQ=MessageBox.Show(customPropertyName, "Run Qty Rule",MessageBoxButtons.YesNoCancel,MessageBoxIcon.Question) If oQ=vbYes oDone() ElseIf oQ=vbNo Call oProject ElseIf oQ=vbCancel MessageBox.Show("Cancelled", "GDI iLogic", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1) Return End If End Sub Sub oDone oCompDef = ThisDoc.Document.ComponentDefinition openDoc = ThisDoc.Document customPropertyName = "Total Qty" 'Open the document that inventor has in focus right now For Each docFile In openDoc.AllReferencedDocuments 'FNamePos is getting the number of spaces that it takes to get to the 'very last back slash in the full file name of our document. FNamePos = InStrRev(docFile.FullFileName, "\", -1) 'We can then take that number (position) and use it to cut off all of the 'file path that we don't need. In this case, it's the front of the path 'that we're getting rid of, leaving us with just the file name. docFName = Mid(docFile.FullFileName, FNamePos + 1, Len(docFile.FullFileName) -FNamePos) 'Let's make sure that we can even change this part. If we can, then we'll continue. If docFile.IsModifiable = True Then 'Because you can only grab the occurrences from an assembly document 'we need to fill up that empty AssemblyDocument container with an object 'that we know is definitely an assembly document. Because that was one 'of the first checks we made up there on this open document, we can safely 'declare that assemblyDoc (Which is an AssemblyDocument) is equal to ' openDoc (Which is just a regular old Document) assemblyDoc = openDoc 'While we're at it, let's go on and define the empty ComponentDefinition container '(we named ours assemblyDef) with some sort of content. assemblyDef = assemblyDoc.ComponentDefinition 'Now we need to collect every instance of the document against 'our open assembly and put them all inside of partQty. partQty = assemblyDef.Occurrences.AllReferencedOccurrences(docFile) 'Now that we have our collection of instances, we need to populate 'our target iproperty with the total amount. 'Instead of just throwing that amount in there, let's make sure that 'the value inside of the target iProperty isn't already equal to our count. 'If it is equal, then we don't have to change anything (which saves us time!), 'but if it isn't equal then we will need to change it. 'The Try statement is here because of the next if statement --- 'If we just compare the two values, there is a small chance that our target 'iProperty is already set to something that is NOT a number, which would create 'an error (as you can't compare numbers against things that aren't numbers). 'So, we TRY to complete that if statement, and if there is an error (The CATCH) 'we just force that target to equal our part qty total. Try If partQty.Count <> iProperties.Value(docFName, "Custom", customPropertyName) Then iProperties.Value(docFName, "Custom", customPropertyName) = partQty.Count End If Catch iProperties.Value(docFName, "Custom", customPropertyName) = partQty.Count End Try End If Next '29/01/2016 'I added the following to create the value for the GA 'Some code automation in the Detailing environment was 'failing because it could not find a valid entry. 'This is a dummy field, and does not contribute to the rest of the inteligence of the rule. Try oASSYParam= iProperties.Value("Custom",customPropertyName) Catch iProperties.Value("Custom",customPropertyName) = "1" End Try iLogicVb.UpdateWhenDone = True MessageBox.Show("Completed" & vbNewLine & ":-)", "Completed", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1) End Sub
Devon Johnson
Inventor 2020
