Option configuration turning back to default if no Network license is detected
Here in my office we have several pc's running Inventor 2012 and we found out that when a network license is unavailable (the number of licenses is exceeded) then Inventor loses some of its configurations on OPTION window. The fields that are erased and put back to default:
- "General" Tab >> "Load VBA on start-up" is set to false;
- "General" Tab >> "Update physical properties on save" is set to false and "Parts and Assemblies" is unchecked;
- "File" Tab >>  "Default VBA project" is set back to default;
- "Contet Center" Tab >> "Location of Libraries" is set to default
- Customized buttons on Ribbonbar loses its icons and we have to recreate them everytime it happens.
Please could someone have a fix and a new implementation for the new versions to come?
I made myself a REG file so that this process ease.
But I still wait the case to be analized, sure others users have the same issue.
Here we have Windows 7 Pro 64 bits
I second this issue.
Anyway you could share what you did with the REG file?
ok bennywise578
Here is our reg file. Please note that I just accessed the registry of a well configurated machine and exported some keys, then I mixed them all inside the same file.
The keys are selfexplained in most cases because their name match with those found on OPTIONS in the English version.
You just need to build something similar and then double click the file to fix the computer.
