OPENING DRAWING DIRECTLY FROM MODEL - MODEL & DRG NAME PLUS LOCATION DIFFERENT
sguan1212
Message 1 of 47
sguan1212
I found this query on an old post that are UNSOLVED. Time has change, revisitation is merited.
All the companies I've work for, both model name & drawing name are always different & saved in 2 different sub-folders under the same project folder. Therefore i've never had the luxury to use OPEN DRAWING command from the model. (Understanding that the model name & drawing name needs to be the same and in common location to work).
Has anyone workout a way get around this?
This problem has been bugging me for years. Any help would be appreciated.
Sean
Replies (46)
Message 41 of 47
sguan1212
Hi Marcin,
The rule seems to be working okay. But...
When I do the initial save of the drawing, the model closes by itself.
Same for the assembly model when the drawing is saved the 1st time.
I would like to keep the models open until they are wanted to be closed
Message 42 of 47
marcin_otręba
So remove doc.close(True) statements then..
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
Message 43 of 47
sguan1212
Hey Marcin,
I think we got somewhere with this one.
I removed the line like you said. There are 2 of them. I deleted the bottom one, still the same, then went ahead and deleted the top one as well. Run another test, and everything worked perfectly.
However, before I jump ahead of myself, I will do another larger scale test to make sure everything is stable.
I really appreciate your help, and all the other guys involved.
Let me come back to you soon
Message 44 of 47
sguan1212
Hi Marcin,
I have successfully done another test without encountering any issues. However, I will have this ilogic rule running as trail for a while before we adopt it fully. Despite that, I think it will be okay to state now that we have a win!!!
Thanks again for all your effort.
I don't know where about on this planet you are. But if you are ever in Melbourne, Australia. I will be glad to shout you a few beers
Message 45 of 47
NachoShaw
Hey
I made something to combat this a while ago, it worked like this(on a multi sheet drawing):
Run macro in Drawing.
    loop through each sheet
        loop through each drawing view and opens (visible = false) each reference.
            add full drawing path and current sheet number to a custom iproperty
        next
   next
added a custom popup form. when i selected a part or assembly, the form would display all of the information (material, appearance, size, drawing and sheet number).
If i clicked 'open drawing, it would simply open the drawing from the path saved in the iproperties and then activate the sheet based on the saved number.
worked for me 🙂
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 46 of 47
sguan1212
Do you still have a copy of the macro, if you can share this, it can be used as an alternative options.
That way people can find it in 1 place
Message 47 of 47
marcin_otręba
Sadly i am not even close (only 15 871 km) so maybe next time 🙂
Ideas
or check my apps:
