Opening an Excel spreadsheet by using a "Public Function"
isocam
Message 1 of 1
isocam
Can anybody help???
I an trying to create a Public Function for opening and closing a Excel Spreadsheet so that I can read data contained in the spreadsheet.
My program uses the following to open a Excel Spreadsheet
Public Function CentreDrillData()
    Dim oXl As Object
    Dim oXlWorkBook As Object
    Dim oXLWorkSheet As Object
    Set oXl = CreateObject("Excel.Application")
    Set oXlWorkBook = oXl.Workbooks.Open(ToolDataFileName)
    Set oXLWorkSheet = oXlWorkBook.Sheets(2)
    For Counter = 3 To 13
        If CentreDrillSize = Trim(oXLWorkSheet.cells(Counter, ToolDescriptionCell).Text) Then
           SpindleSpeed = oXLWorkSheet.cells(Counter, PartMaterialCell + 1).Text
           Depth = oXLWorkSheet.cells(Counter, ToolDescriptionCell + 1).Text
           Exit For
        End If
    Next
    Call CloseExcel(oXlWorkBook, oXl)
End Function
The CloseExcel works OK
I want to put the first 6 lines into a Public function thus....
Public Function OpenExcel(l)
    Dim oXl As Object
    Set oXLWorkSheet = oXlWorkBook.Sheets(ExcelSheetNumber)
End Function
But this Public Function does not work!
I want to replace the first lines of the main function to Call OpenExcel.
Does anybody know what is wrong????
Many thanks in advance!!!
IsoCAM
Replies (0)
