Hi, here is a method that returns the number of names you need, which are generated in the vault. This might help you:
- "RequiredSchemeName" <-- Scheme name
- "RequiredSchemeString" <-- Can be empty
- numberOfNames <-- The number of names you need.
You must remember not to enter too large a number by accident, because that amount will be reserved in the Vault.
'heading
AddReference "Autodesk.Connectivity.WebServices"
AddReference "Autodesk.DataManagement.Client.Framework.Forms"
AddReference "Autodesk.DataManagement.Client.Framework.Vault"
AddReference "Autodesk.DataManagement.Client.Framework.Vault.Forms"
AddReference "Connectivity.InventorAddin.EdmAddin"
Imports ACW = Autodesk.Connectivity.WebServices
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports Autodesk.DataManagement.Client.Framework.Vault.Services
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections
Imports edm = Connectivity.InventorAddin.EdmAddin
Here is a function, which return List with number from vault.
Function getFilenamesFromVaultNamingScheme(RequiredSchemeName As String, RequiredSchemeString As String, numberOfNames As Integer)
Dim Connection As VDF.Vault.Currency.Connections.Connection = edm.EdmSecurity.Instance.VaultConnection()
Dim genNum As String = String.Empty
Dim names As New List(Of String)
If Not Connection Is Nothing Then
Dim entityClassId = VDF.Vault.Currency.Entities.EntityClassIds.Files
Dim numSchemes As ACW.NumSchm() = Connection.WebServiceManager.NumberingService.GetNumberingSchemes(entityClassId, Nothing)
Dim requiredScheme As ACW.NumSchm = (From sch As ACW.NumSchm In numSchemes
Where sch.Name = RequiredSchemeName
Select sch).FirstOrDefault()
Dim numGenArgs() As String = {RequiredSchemeString}
For i = 1 To numberOfNames
genNum = Connection.WebServiceManager.DocumentService.GenerateFileNumber(requiredScheme.SchmID, numGenArgs)
names.Add(genNum)
Next
Return names
End Function
