Open Vault's "Generate File Number" pop-up using API
carlos_henrique37ZCB
Hi everyone,
This pop-up will appear each time I use a 'Save As' option. When using the API to 'Save As' a file, the pop-up does not show up, and I can't use the Vault's file number generator, which I must. It seems like it is not implemented in the API yet. Are there any workarounds? I need to save many files at once, and without the API, I will have to do this manually because the files must be saved with the correct number sequence.
could be something as simple as:
Dim VaultFileName As String
VaultFileName = 'opens pop-up so I can select the next code of the file name and returns the string'
Thanks for the help
m_baczewski
Hi, here is a method that returns the number of names you need, which are generated in the vault. This might help you:
  • "RequiredSchemeName" <-- Scheme name
  • "RequiredSchemeString" <-- Can be empty
  • numberOfNames <-- The number of names you need.
You must remember not to enter too large a number by accident, because that amount will be reserved in the Vault.
'heading
AddReference
"Autodesk.Connectivity.WebServices" AddReference "Autodesk.DataManagement.Client.Framework.Forms" AddReference "Autodesk.DataManagement.Client.Framework.Vault" AddReference "Autodesk.DataManagement.Client.Framework.Vault.Forms" AddReference "Connectivity.InventorAddin.EdmAddin" Imports ACW = Autodesk.Connectivity.WebServices Imports VDF = Autodesk.DataManagement.Client.Framework Imports Autodesk.DataManagement.Client.Framework.Vault.Services Imports Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections Imports edm = Connectivity.InventorAddin.EdmAddin
 Here is a function, which return List with number from vault.
Function getFilenamesFromVaultNamingScheme(RequiredSchemeName As String, RequiredSchemeString As String, numberOfNames As Integer)
Dim Connection As VDF.Vault.Currency.Connections.Connection = edm.EdmSecurity.Instance.VaultConnection()
Dim genNum As String = String.Empty
Dim names As New List(Of String)
If Not Connection Is Nothing Then
	Dim entityClassId = VDF.Vault.Currency.Entities.EntityClassIds.Files
	Dim numSchemes As ACW.NumSchm() = Connection.WebServiceManager.NumberingService.GetNumberingSchemes(entityClassId, Nothing)
	Dim requiredScheme As ACW.NumSchm = (From sch As ACW.NumSchm In numSchemes
	Where sch.Name = RequiredSchemeName
	Select sch).FirstOrDefault()
	Dim numGenArgs() As String = {RequiredSchemeString}
	For i = 1 To numberOfNames
		genNum = Connection.WebServiceManager.DocumentService.GenerateFileNumber(requiredScheme.SchmID, numGenArgs)
		names.Add(genNum)
	Next
End If
	Return names
End Function
