Open Inventor Part With the help of excel vba
Message 1 of 20
Hello Friends,
Could you please tell me, Is there any option to open inventor part by excel vba user form.
Thirty different types of door series are include in one part using multiple extrude,cut, and other features and i have drives those different series with the help of combo box from excel vb.net user form sheet also drive different parameter like Door Width, Length and Thickness by same excel. All parameters are worked and updated in inventor model. But i want, when i put all the value of parameter in excel user form and click on the DONE button then part will be open and get update as per excel parameter then after it will be closed.
please see below excel vb.net user form for you reference.
Parth Patel
Replies (19)
Message 2 of 20
frederic.vandenplas
You can use this code but you must add a reference in Excel vba (Tools->References)
Then you can use this code to open the file:
Sub OpenInventorDocumentFromExcel()
Dim strFile As String
strFile = "Fill In Full Filename of the document"
Dim InvApp As Inventor.Application
'If you like to create a new inventor instance
Set InvApp = CreateObject("Inventor.Application")
'if you like to use an open instance of inventor
'Set inventorApp = GetObject(, "Inventor.Application")
InvApp.Visible = True
Call InvApp.Documents.Open(strFile, False)
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 3 of 20
Message 4 of 20
I need another help.
when i update my excel user form parameter and click on the button then part is open but it is not updated as per my excel user from parameters and selection.
It is update when i was close my excel sheet and run i-logic rules manually from i-logic rule tab which is in my model.
Parth
Message 5 of 20
frederic.vandenplas
If you do the steps manually (as i allways do before programming i write down all the steps i need to program.) you wille see
that you need to save the excel file, before or after opening the document. And to be sure doc.rebuild or doc.rebuild2
If your excel is not saved, inventor will look at the value when the document was last saved.
Message 6 of 20
Thank you very much
Its worked very well.
Message 7 of 20
HI,
When i have change the parameters of model from excel user form and click user from button then my model have open and update as per my excel user from parameters.but after when i have change model parameters from excel user form it's not update in my model.
Is there any option to live update inventor model by clicking excel user form button when model and excel both are open?
Message 8 of 20
frederic.vandenplas
If you call this sub in every sub/function you have in excel then your model will update.
You could also raise an excel event on changing cells
Sub Button1_Click() 'this is a button in excel or form in vba
ActiveWorkbook.Save 'Don't forget to save
LiveUpdate
End Sub
Sub LiveUpdate()
Set InvApp = GetObject(, "Inventor.Application")
Dim oDoc As PartDocument
Set oDoc = InvApp.ActiveDocument
oDoc.Rebuild
End Sub
Message 9 of 20
Hi Frederic,
When i have upload the Live Update vba code and click on the button then below error occur.
it's stop at oDoc.Rebuild.
Message 10 of 20
frederic.vandenplas
The error occuring is most likely because your document is not open, my snippet is perfectly working here.
You have to make sure that you first open the document you need to update
Set oDoc = Invapp.document.open("fullfilename",True)
What i don't know from your explanation is if you want to open a part/assembly/drawing.
So if you declare oDoc, you need to modify this:
Dim oDoc as PartDocument (or AssemblyDocument or DrawingDocument )
Or alternatively you could do this (less advised)
Dim oDoc as Document
Message 11 of 20
Hi frederic,
As instructed by you i have follow the rule and it's worked up to excel sheet. when i have click my button then the user form parameters pass into my excel cells and it's save and also opened inventor part window is flashing  whenever i have clicking button but my part is not update as per my excel cells value.
Please help.
Parth
Message 12 of 20
frederic.vandenplas
Can you please provide a full sample of what you are trying to achieve (excel file, inventor file, code...)
That would be more realistic to test because your close, but something missing that i can't see or know.
Message 13 of 20
Hi Frederic,
Please find enclosed here with zip folder of my model with excel.
In folder i have placed another folder of door series images for your reference of door series types which is include in my model.
Parth
Message 14 of 20
Hi Frederic,
What  about my model? is there worked?
Parth
Message 15 of 20
frederic.vandenplas
Sorry for my late response, busy here Smiley Tongue
I took a decent look at your project and here is my resolution
First of al, it's easier if you make a relative path for referenced documents, if you move your project then there's no need to alter the code.
for example:
'oWB = oExcel.Workbooks.Open("C:\Users\parth.vpatel\Desktop\BARN DOOR\DOOR DESIGN TOOL.xlsm")
oWB = oExcel.Workbooks.Open(ThisDoc.Path & "\DOOR DESIGN TOOL.xlsm")
But when i look deeper into your project, i would suggest to NOT use excel for this, you can make it much easier if you just use an iLogic form where you place the parameters.
So i've recreated the excel as an ilogic form "Door Design Tool" with the parameters included and a button to run the rule if needed.
I also supressed the rule for excel, because it's eliminated.
The modified project is included as an attachment, if in doubt, just ask!
Message 16 of 20
Hello Frederic,
Sorry for late replay due to workload.
Yes, i understood and i will done that. But just for knowledge can you tell me, Is that possible live update inventor model with excel?
Parth
Message 17 of 20
frederic.vandenplas
I've digged a little deeper in the live update, and update, update2, rebuild, rebuild2 does NOT work persistent.
So i've came up with the idea to move the EndOfPart feature to the top of the browser, and place it back to the end of the browser.
That invoked an update of the model (finally)
Attached you can find a working example with code in excel, and also a sub that should work on your model.
Message 18 of 20
Hello Frederic,
Sorry for late reply.
Thank you very much.
it's worked very well.
Regards
Parth
Message 19 of 20
frederic.vandenplas
Nice to hear that!
Message 20 of 20
Hello Frederic,
Could you do me a favaour regarding below?
I have an assembly model in which i am create i logic rules. All rules are worked and update the model but i want to one extra thing. which  is, when i am entering the new project number from user form and click the apply button from user form then the whole assembly and its parts generate with new project number with appropriate new project folder and delete all rule from generated new assembly model.  See below what i am exactly looking,
My Master Model,
1) Master Model- 2200
    Master Model File Path:-E:\Project\2200\
    Master Model Assembly Parts- 2200-001
    Master Model Assembly Parts- 2200-002
    Master Model Assembly Parts- 2200-003
Generated New Model Assembly
2) New Model- 2300
    New Model File Path:-E:\Project\2300\
    New Model Assembly Parts- 2300-001
    New Model Assembly Parts- 2300-002
    New Model Assembly Parts- 2300-003
Parth
