Activate Next Sheet Shortcut and Activate Previous sheet Shortcut
k14348
k14348
  I'm planning to create a shortcut key for Previous Sheet Activate Shortcut and Next Sheet Activate Shortcut via Vba program. Can Anybody help?
-karthikeyan M
Hi Karthi,
You can assign the key to the following macros using customize option available in the Tools Tab.
Snippet Code to activate next sheet of active sheet
Sub Forward()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheetName As String
oSheetName = oDrawDoc.ActiveSheet.name
Dim oSheet As Sheet
Dim oSheetCount As Double
oSheetCount = oDrawDoc.Sheets.Count
i = 0
For Each oSheet In oDrawDoc.Sheets
    i = i + 1
    If oSheetName = oSheet.name Then
        If i < oSheetCount Then
            oDrawDoc.Sheets.Item(i + 1).Activate
        Else
            MsgBox "Reached Last Sheet"
Next
End Sub
Snippet Code to activate previous sheet
Sub Backward()
Dim oSheet As Sheet
i = 0
    i = i + 1
        If i > 1 Then
            oDrawDoc.Sheets.Item(i - 1).Activate
        Else
            MsgBox "Reached First Sheet"
Next
End Sub
nbonnett-murphy
If you come across this in 2023, you'll need to change a couple small things before you can paste these straight into an iLogic script.
Prev sheet:
Sub main()
Dim oSheet As Sheet
i = 0
    i = i + 1
        If i > 1 Then
        Else
Next
End Sub
Next sheet:
Sub main()
oSheetName = oDrawDoc.ActiveSheet.Name
Dim oSheet As Sheet
i = 0
    i = i + 1
    If oSheetName = oSheet.Name Then
        Else
            MsgBox ("Reached Last Sheet")
Next
End Sub
