Open from Vault and On File Close Event Triggers
Matthew_Policelli
Matthew_Policelli
When opening a file from vault, I get prompts from iLogics in the On File Close event triggers.
Is there a line I can add to my iLogic so that this doesn't happen? I only want it when I'm actually closing the file, not when Inventor opens then closes then reopens the file (for whatever reason it has to do so).
Frederick_Law
Event trigger will trigger no matter what.
Add code to the trigger to "filter out" what you don't want.
