Open existing Excel file using GoExcel options
karram
karram
Using iLogic below code with "GoExcel" options, how can i open Excel file to be the one that exists in the workspace location.
But the important logic is "that file name characters changes all the time and last three characters always be "000".
This kind of case how to access the Excel file name
GoExcel.Open("Excelfilename", "Sheet1")
A.Acheson
Does the filename in any way match the assembly. part filename? If not you will need to search the folder directory for all excel files and check then if they contain "000".
This post here covers it well.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/find-and-open-excel-file-in-folder/t...
Regards
Alan
