how to create password for External ilogic rules
karram
karram
How can i create the password for Extrernal ilogic rules.
Is there any possibilities to lock the codes, some kind of key user rights
Thanks and Regards,
Karthick
Michael.Navara
Protect iLogic rule by password is not possible. iLogic needs access to rule text in readable form.
But you can extract your code for example to compiled external DLL file. Later on you can call the code from your DLL.
Or you can convert your iLogic rules to addin which is compiled DLL also.
JelteDeJong
you could set the security options of the iLogic file or put them in a folder with special premissions.
The other way as mentioned by @Michael.Navara is creating an addin from your iLogic rules. I wrote a tutorial on how to do that. You can find it here: http://www.hjalte.nl/60-creating-an-inventor-addin
Jelte de Jong
Blog: hjalte.nl - github.com
