open drawing deferred vba ignore ilogic form error log print close next
andrew_canfield
andrew_canfield
I've found some code to open a drawing using VBA & it works 🙂
I'd like to open with deferred updates on.
But some drawings have embedded code (before my time) & an ilogic rule checks iproperties  - i'd like to skip the code to just print the drawing.
on error log the drawing number & close. (some fea files are causing resolution issues)
no error then print (the default printer will be set to pdf)
close
goto the next file in the list (or selected - possibly over complicating at this stage)
Basically this is to batch print as pdf but dialogue boxes keep interrupting
below is the iLogic form which needs closing.
iLogic formiLogic form
Regards
Andrew
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield,
All iLogic triggers can be disabled manually as shown in below image. After disabling iLogic trigger, VBA code can be used to print all drawings to PDF. Later, event triggers should be enabled to trigger iLogic rules.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
andrew_canfield
Thankyou.
Any pointers on skipping file resolutions (fea files in particular) ?
Not sure how to create a batch either...
Andrew
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield,
Hoping that below VBA code may be helpful to print all drawing files.
Public Sub ListESY()
    Const strFolder As String = "C:\Temp\"
    Const strPattern As String = "*.dwg"
    Dim strFile As String
    Dim oDoc As DrawingDocument
    strFile = Dir(strFolder & strPattern, vbNormal)
    Do While Len(strFile) > 0
        Debug.Print strFile '<- view this in Immediate window; Ctrl+g will take you there
        Set oDoc = ThisApplication.Documents.Open(strFolder & strFile, True)
        'Code to Print PDF
    Loop
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
andrew_canfield
unfortunately the folder is huge!
i'd like to cherry pick which drawings are needed & add them to a print queue.
Investigating further - thankyou
