Open document from drawing partslistrow
I wish to open a part or assemblydocument by its item number in the drawingdocument.
I can make an inputlistbox with all Item numbers in the drawing.
I can also link the result of the inputlistbox to the partslistrow.Item("Item").Value.
I am stuck here. I can not find the link/reference from a partslistrow to a document.
Is there a propertyfield that keeps the link? Or another way?
Comparing partlist and BOM cells by value is not a method I can use
Thanks in advance,
Arnold
jdkriek
Look at the PartsListRow.ReferencedFiles Method
Here's a quick example:
Public Sub OpenPartFromList()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Get the part list
    Dim oPartList As PartsList
    Set oPartList = oDoc.ActiveSheet.PartsLists.Item(1)
    ' Find the first row
    Dim oRow As PartsListRow
    Set oRow = oPartList.PartsListRows.Item(1)
    ' Get Ref Doc
    Dim oRefDoc As Document
    Set oRefDoc = oRow.ReferencedFiles.Item(1).ReferencedDocument
    ' Open the doc
    ThisApplication.Documents.Open (oRefDoc.FullDocumentName)
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Thats it! thanks
Hi All,
Any chance to mod this code to open the model from first sheet ,first view instead BOM?
