Open assy from the same folder as drawing
tomislav.peran
tomislav.peran
This is a code used to make a view from the assy. In a code I have to write the location of the assy.
Since the drawing and the assembly are in the same folder I would like to find a way not to write the exact location of the assy. I tried a few things but it did not work.
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint1 As Point2d
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(5#, 5#)
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.Documents.Open(C:\...\"My_assy.iam", False)
Dim oView1 As DrawingView
oView1 = oSheet.DrawingViews.AddBaseView(oAssyDoc, _
    oPoint1, 1#, kBottomViewOrientation, kHiddenLineDrawingViewStyle)
Call oAssyDoc.Close(True)
 If somebody could help it would be great 🙂
Tom
WCrihfield
I noticed the character "#" in 3 places within your posted code.  Did that get automatically converted from some other character by the post?  Was that supposed to be a zero?  I removed that character from those 3 locations when I created the edited version below for you to try out, so you may need to fix those values if that's not correct.
Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(5, 5)
Dim oPath As String = System.IO.Path.GetDirectoryName(oDrawingDoc.FullFileName)
Dim oAssyFullFileName As String = System.IO.Path.Combine(oPath, "My_assy.iam")
Dim oAssyDoc As AssemblyDocument = ThisApplication.Documents.Open(oAssyFullFileName, False)
    oPoint1, 1, kBottomViewOrientation, kHiddenLineDrawingViewStyle)
Wesley Crihfield
(Not an Autodesk Employee)
tomislav.peran
Hi WCrihfield,
Thank you a lot! I am using Inventor Programming/API help to learn more about how to create codes in Inventor.
Code that I pasted is found here (only original code is used for the part and I changed it for assembly):
https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-66470F9F-8563-4D53-91BE-F4769943E71C
There they use symbol #. They also use term "Set"  which actually I delete every time I am trying out the code. I assume that is Visual Basic thing but I have no idea.
Tom
WCrihfield
OK.  I see now.  Those are examples for use in VBA.  That's why they are using the 'Set' keyword at the beginning of a line that sets the value of a variable.  That term is not needed for that purpose in iLogic or vb.net.  And the "#" symbol can be used for directly interpreting a variable as a Double data Type.  Here is a link to a page about it in vb.net (vb.net is used by iLogic).  I just don't see it used that much in iLogic.
Wesley Crihfield
tomislav.peran
Hi WCrihfield,
Thanks a lot for the explanation and for the link! Finally that is clear as well 🙂
Tom
