Open assembly of selected view
josh.linares-stanley
Could someone provide a short rule to open the part/assembly of a drawing view when selected using the snippet below?
ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
Andrii_Humeniuk
Hi @josh.linares-stanley . Try this iLogic code:
Dim oInvApp As Inventor.Application = ThisApplication
Dim oDoc As Document = oInvApp.ActiveDocument
If Not TypeOf oDoc Is DrawingDocument Then Exit Sub
Dim oDDoc As DrawingDocument = oDoc
Dim oView As DrawingView
oView = oInvApp.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
If oView Is Nothing Then Exit Sub
oDoc = oInvApp.Documents.Open(oView.ReferencedDocumentDescriptor.FullDocumentName, True)
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
A.Acheson
Hi @josh.linares-stanley  from this API sample here for the referenced document
And to open the find document use Documents.Open
Dim drawView as DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
Dim refDoc As Document = drawView.ReferencedDocumentDescriptor.ReferenceDocument
ThisApplication.Documents.Open(refDoc.FullFileName,True)
Regards
Alan
Works a charm, thanks
