Open a iLogic form external
Hello there!
I have make a iLogic form to edit my window parameter and save it as dwg.
Is there a way to open my ipt file hidden so that i can just see my userform?
Owner2229
Hi, you can try this one:
Dim oDoc As Document = ThisApplication.Documents.Open("C:\SomePath\MyPart.ipt", False)
'... do something with the document
oDoc.Save
oDoc.Close
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
