OnInitializeDocument : HandlingCode doesn't work
alder_moriggi
alder_moriggi
Hi all, in .net I would like to intercept the file creation on "OnInitializeDocument" event and undo operation (or confirm) in a certain conditions.
I set the "HandlingCode" parameters (HandlingCodeEnum.kEventCanceled or HandlingCodeEnum.kEventHandled) but in both cases it creates the file.
Anything else to set? What's wrong?
TIA
Alder
Private Sub m_appEvents_OnInitializeDocument(DocumentObject As _Document, FullDocumentName As String, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles m_appEvents.OnInitializeDocument
Try
If Cancel_Event then
HandlingCode = HandlingCodeEnum.kEventCanceled
Else
HandlingCode = HandlingCodeEnum.kEventHandled
Catch ex As Exception
End Try
End Sub
YuhanZhang
Hi Alder,
Please refer to the documentation for the event:
https://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-EDA1CDB1-0BF3-46CD-8535-DDA6D973EAC2
The HandlingCode is ignored for this event, so you can't use this event to cancel the operation.
Can you explain what you want to do? What is your workflow and why you need to cancel the document opening?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
