One-click for all components
deffysalfauzi
Message 1 of 18
deffysalfauzi
Please help.
I have many structural parts in an assembly/subassembly file. How to activate the code for each part in the assembly/subassembly and update it every time the size changes.
In the future, I hope this code can also be implemented for all structural parts & sheet metal in assembly.
'Structural shapes, i.e : Angle Bars
iProperties.Value("Custom", "Height") = Round(G_H,0)
iProperties.Value("Custom", "Thickness") = Round(G_T,0)
iProperties.Value("Custom", "Length") = Round(G_L,0)
iProperties.Value("Project", "Description") = "=Angle Bar - <Material>, <Height>x<Height>x<Thickness> x <Length> mm"
'Sheet Metal
iProperties.Value("Custom", "Thickness") = Round(Thickness,1)
iProperties.Value("Custom", "Length") = Round(SheetMetal.FlatExtentsLength,0)
iProperties.Value("Custom", "Width") = Round(SheetMetal.FlatExtentsWidth, 0)
iProperties.Value("Custom", "Weight") = Round(iProperties.Mass, 2)
iProperties.Value("Project", "Description") = "=<Material>, <Thickness> x <Length> x <Width> mm"
Replies (17)
Message 2 of 18
AndrewHumiston
are you asking to do a mass update of all parts in an assembly, targeting those specific custom iproperties?
can you attach a sample file of a pack and go, with a few items of each type in the file for testing pleases.
Message 3 of 18
daltonNYAW9
Instead of creating custom iproperties for "Sheet metal width" you could just use the default ones
<Sheet Metal Width>, <Sheet Metal Area>, <Flat Pattern Area>
Also, you could just add the "G_H", etc to your custom iproperties without making new values.
Try this: (minimum testing)
Dim oADoc As AssemblyDocument = ThisDoc.Document
For Each oPartDoc As PartDocument In oADoc.AllReferencedDocuments.OfType(Of PartDocument)
	If oADoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oPartDoc).Count = 0 Then Continue For
	If oPartDoc.PropertySets.Count = 6
		'custom content center part
		If oPartDoc.PropertySets("ContentCenter")("IsCustomPart").Value = True
			'create family property or add to cc template table
			'add family name as custom property
			Dim familyName As String = oPartDoc.PropertySets("Content Library Component Properties")("Family").Value
			Dim oFamilyProp As Inventor.Property
			Try
				oFamilyProp = oPartDoc.PropertySets(4).Item("Family")
			Catch
				oFamilyProp = oPartDoc.PropertySets(4).Add("", "Family")
			End Try
			'set family value
			Select Case familyName
				Case "ANSI AISC (Square)"
					oFamilyProp.Value = "Angle Bar"
				Case "angle"
			End Select
			'get all parameters you want displayed as custom properties
			Dim oParamG_H As Inventor.Parameter = oPartDoc.ComponentDefinition.Parameters.Item("G_H")
			Dim oParamG_T As Inventor.Parameter = oPartDoc.ComponentDefinition.Parameters.Item("G_T")
			Dim oParamG_L As Inventor.Parameter = oPartDoc.ComponentDefinition.Parameters.Item("G_L")
			For Each item As Inventor.Parameter In {oParamG_H, oParamG_T, oParamG_L }
				With item
					.ExposedAsProperty = True
					.CustomPropertyFormat.Units = "mm"
					.CustomPropertyFormat.ShowUnitsString = True
					.CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
				End With
			Next
		'update description
		oPartDoc.PropertySets(3)("Description").Value = "=<Family> - <Material>, <Height>x<Height>x<Thickness> x <Length> mm"
		End If
	ElseIf oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
		'sheet metal part
		'add thickness to custom properties
		Dim oParamThick As Inventor.Parameter = oPartDoc.ComponentDefinition.Parameters.Item("Thickness")
		With oParamThick
			.CustomPropertyFormat.ShowUnitsString = False
		End With
		'update rounding of sheet metal lengths
		oPartDoc.UnitsOfMeasure.LengthDisplayPrecision = 0
		oPartDoc.Rebuild
		'add weight property
		Dim oMassProp As Inventor.Property
		Try
			oMassProp = oPartDoc.PropertySets(4).Item("Weight")
			oMassProp.Value = Round(oPartDoc.ComponentDefinition.MassProperties.Mass, 2)
		Catch
			oMassProp = oPartDoc.PropertySets(4).Add("", "Weight")
		End Try
		'update description
		oPartDoc.PropertySets(3)("Description").Value = "=<Material>, <Thickness> x <Sheet Metal Length> x <Sheet Metal Width>"
	End If
Next
Message 4 of 18
deffysalfauzi
@AndrewHumiston please check the picture below, thank you.
@daltonNYAW9 This is the result of the code you created :
Spoiler
Screenshot 2024-07-19 233939.pngScreenshot 2024-07-19 234004.pngScreenshot 2024-07-19 234046.pngScreenshot 2024-07-19 234104.png
This is the expected result (for Rules or External Rules) :
It's very tiring, if you create 1 rule for each structural part with hundreds of parts, so I expect that with 1 rule at the top level assembly I can create a custom iProperties & Project Description.
The code I used for 1 file Angle Bars :
The code I used for 1 sheet metal :
'Sheet Metal
Message 5 of 18
daltonNYAW9
@deffysalfauzi
You will have to develop some of this yourself. The case statement is meant to filled out with all of the content center family names. You could also edit your cc directly to have names such as "Angle Bar" to add to the iproperties.
Change the line that changes the description to this:
You will need to add "G_W" as well for uneven angles/tube in the future
oPartDoc.PropertySets(3)("Description").Value = "=<Family> - <Material>, <G_H>x<G_H>x<G_T> x <G_L> mm"
The sheet metal one probably didn't work because there wasn't already a flat pattern. You could add some lines to create a flat pattern, and a temp view to maintain the assembly environment.
Something like this:
Dim tempview As Inventor.View = oADoc.Views.Add
tempview.Activate
'for loop
'sheet metals
'create flat pattern
	If oPartDoc.ComponentDefinition.HasFlatPattern = False
		Try
			oSMCD.Unfold
			oSMCD.FlatPattern.ExitEdit
		Catch
			Continue For
		End Try
	End If
'next
tempview.Close
Message 6 of 18
daltonNYAW9
Heres a revised version:
tempview.Activate
			Try
			Catch
			End Try
			'set family value
				Case "angle"
			End Select
			Dim olist As New List(Of Inventor.Parameter)
			Dim oParamG_W As Inventor.Parameter
			Try
				oParamG_H = oPartDoc.ComponentDefinition.Parameters.Item("G_H")
				olist.Add(oParamG_H)
			Catch : End Try : Try
				oParamG_W = oPartDoc.ComponentDefinition.Parameters.Item("G_W")
				olist.Add(oParamG_W)
				oParamG_T = oPartDoc.ComponentDefinition.Parameters.Item("G_T")
				olist.Add(oParamG_T)
				oParamG_L = oPartDoc.ComponentDefinition.Parameters.Item("G_L")
				olist.Add(oParamG_L)
			Catch : End Try
			For Each item As Inventor.Parameter In olist
				With item
				End With
			Next
			'update description
			oPartDoc.PropertySets(3)("Description").Value = "=<Family> - <Material>, <G_H> x <G_H> x <G_T> x <G_L> mm"
		End If
		'sheet metal part
		Dim oSMCD As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
		If oSMCD.HasFlatPattern = False
			Try
				oSMCD.Unfold
			Catch
				Continue For
			End Try
		End If
		With oParamThick
		End With
		oPartDoc.Rebuild
		Try
		Catch
		End Try
		'update description
	End If
Next
tempview.Close
Message 7 of 18
deffysalfauzi
@daltonNYAW9 Thank you, I'm very happy for your respons.
This is the result with the code you created.
The ‘<Family>’ does not appear in the description (structural shapes)
Thickness, Length & Height (=G_H = Width in BoM) does not appear in the custom
Perfect, but can the thickness be made x,x leading zero, ie :
0,5 --> 0,5
1,0 --> 1
1,5 --> 1,5
I need this all : Thickness, Length & Width
This is the reason why I need Custom iProperties earlier.
Thank you for helping, I was assisted by Google Translate, and I hope you can create the code.
Message 8 of 18
daltonNYAW9
The best way to do this would be to edit your content center tables for the structural shapes you want. And add a line that maps to the "Description" property. This would require less coding.
ex:
Then you could manually add the custom iproperties to the template and upload it back to content center
Then link them to your custom iproperties your custom iproperties
Finally, upload the template back to your content center
You will likely need to have code for updating the sheet metal parts, but doing this first would be preferable.
Message 9 of 18
deffysalfauzi
Wow... straight to the content center. Amazing.
But, how to "upload the template back to content center", Can you provide the steps? I don’t know how to do it.
Message 10 of 18
daltonNYAW9
There are some good youtube videos on it.
Its been a while since I've messed with it, but here are some notable problems we had:
1. Create a custom configurable library and copy the ones you want changed there
2. We had a problem with the table parameters updating with model changes, especially for the length paramters 0,001. So we made the length a custom iproperty and made the descreption an equation
3. Keep the family properties... > family description field blank
Good luck with this haha
Message 11 of 18
deffysalfauzi
Amazing, I need your help, one more time. Almost done.
Can you fix the code below, especially in the sheet metal section :
'https://forums.autodesk.com/t5/inventor-programming-ilogic/one-click-for-all-components/m-p/12908444...
tempview.Activate
Try
Catch : End Try
With item
.CustomPropertyFormat.ShowLeadingZeros = True
.CustomPropertyFormat.ShowTrailingZeros = False
.CustomPropertyFormat.Precision = CustomPropertyPrecisionEnum.kOneDecimalPlacePrecision
End With
Next
'update description
oPartDoc.PropertySets(3)("Description").Value = "=<Family> - <Material> - <G_H> x <G_W> x <G_T> - <G_L> mm"
End If
'sheet metal part
Try
oSMCD.Unfold
Catch
Continue For
End Try
End If
'Sheet Metal custom properties :
'Thickness = G_T
'SheetMetal Flat Extents Height = G_H
'SheetMetal Flat Extents Width = G_W
'example in project description : Steel - 1,5 x 100 x 105,5 mm
add thickness To custom properties
With oParamThick
End With
Next
oPartDoc.Rebuild
Try
Catch
End Try
'update description
oPartDoc.PropertySets(3)("Description").Value = "=<Material> - <G_T> x <G_W> x <G_H> mm"
End If
Next
tempview.Close
Message 12 of 18
deffysalfauzi
“Please, how do I export sheet metal extent to custom properties?”
Message 13 of 18
AndrewHumiston
are you using ilogic?
you need to first set up  a rule to export the vaules to a parameter then, you'll check the 'export' option for each parameter.
here is the rule i use in sheetmetal files to get my exported extents values:
Imports Inventor.UnitsTypeEnum
Dim oPartDoc As Document
Dim oPartCompDef As PartComponentDefinition
Dim oParams As Parameters
Dim oUserParams As UserParameters
oPartDoc = ThisDoc.Document
oPartCompDef = oPartDoc.ComponentDefinition
oParams = oPartCompDef.Parameters
oUserParams = oParams.UserParameters
Try
oTester = oUserParams("extents_width")
Catch
oUserParams.AddByExpression("extents_width", "1", kInchLengthUnits)
Parameter.Param("extents_width").ExposedAsProperty = True
Parameter.Param("extents_width").Expression = SheetMetal.FlatExtentsWidth
End Try
Try
oTester = oUserParams("extents_length")
Catch
oUserParams.AddByExpression("extents_length", "1", kInchLengthUnits)
Parameter.Param("extents_length").ExposedAsProperty = True
Parameter.Param("extents_length").Expression = SheetMetal.FlatExtentsLength
End Try
extents_width = SheetMetal.FlatExtentsWidth
extents_length = SheetMetal.FlatExtentsLength
my Event triggers:
Exported Values:
i hope this helps!
Message 14 of 18
deffysalfauzi
The problem is, I have over 500 IPT and IAM files (frames, sheet metal parts, and assemblies). It seems like it would take a significant amount of time to edit each sheet metal part individually. Therefore, I need to find a way to automate this process using iLogic to shorten the time required. I apologize if this seems complex. Thank you for your efforts in assisting me.
Message 15 of 18
AndrewHumiston
Easy Fix!
use your event trigger and store the rule externally.
then any part you open will be wrapped up with the extents information
Message 16 of 18
daltonNYAW9
@deffysalfauzi
Are you just wanting the the custom iproperties to have the correct names?
You can use a try/catch to try and create new custom iproperties
'thickness -> G_T
Try
	oMassProp = oPartDoc.PropertySets(4).Item("G_T")
	oMassProp.Value = Round(oPartDoc.ComponentDefinition.Thickness.Value, 1)
Catch
	oMassProp = oPartDoc.PropertySets(4).Add("", "G_T")
End Try
'thick
Try
	oTProp = oPartDoc.PropertySets(4).Item("Thick")
	oTProp.Value = "=<G_T>"
Catch
	oTProp = oPartDoc.PropertySets(4).Add("", "Thick")
End Try
'width
Try
	oMassProp = oPartDoc.PropertySets(4).Item("G_W")
	oMassProp.Value = Round(oPartDoc.ComponentDefinition.FlatPattern.Width, 0)
Catch
	oMassProp = oPartDoc.PropertySets(4).Add("", "G_W")
End Try
You could bypass a lot of coding if you changed the template file to include "Thickness" parameter and utilize the hidden custom iproperty <Sheet Metal Width>. It would just add an extra "mm" to ur description format
Message 17 of 18
daltonNYAW9
@AndrewHumiston
I havn't messed with global rules much, but u still need to add the "trigger" for every part, right?
Message 18 of 18
AndrewHumiston
Afternoon,
you can add per file, or per file type, see attached screen shot. I hope this helps.
