I have found an example which shows how to offset an rectangle by offset using point option.
Here is a code:
' Create a rectangle Dim oRectangleLines As SketchEntitiesEnumerator Set oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle(oTransGeom.CreatePoint2d(1, 2), oTransGeom.CreatePoint2d(5, 5)) ' Create a new object collection Dim oCollection As ObjectCollection Set oCollection = ThisApplication.TransientObjects.CreateObjectCollection ' Add the first sketch line of the rectangle to the collection oCollection.Add oRectangleLines.Item(1) ' Offset Dim offsettedentities As SketchEntitiesEnumerator Set offsettedentities = oSketch.OffsetSketchEntitiesUsingPoint(oCollection, oOriginSketchPoint.Geometry, True, True)
All that I need now is to adapt code for other type of sketch entity, for example for the arcs.
I tried with folowing code but I am getting error type missmatch.
Dim oArc As SketchEntitiesEnumerator 'I know this declaration makes a problem but if I declare variable as SketchArc I can't add to collection Set oArc = oSketch.SketchArcs.AddByCenterStartEndPoint(oTransGeom.CreatePoint2d(0, 0), oTransGeom.CreatePoint2d(-5, 0), oTransGeom.CreatePoint2d(5, 0), True)
oCollection.Add oArc.Item(1)
' Offset
Can someone help me with this.
Regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
