- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone,
I am searching over the intenet but I have not found yet a way to delete an specific constraint (for example coincident) between two lines.
About lines:
oLine1 = xySketch.SketchLines.Item(1) oLine2 = xySketch.SketchLines.Item(2)
and their coincident relation is:
oLine2.StartSketchPoint.Merge oLine1.EndSketchPoint
I want to break this relation between lines, remove or delete. Every other constraints and relation in the sketch I must keep.
I have found a way to delete all constraints or delete constraints by type but this is not a solution.
Best regards
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
