Hello All,
I create a new sketch on an extrusion face with projected edges
Then i simply want to offset the boundary line of that sketch
I cant find anything similar anywhere that can collect those lines and offset it.
Here is what i have so far in Ilogic:
SyntaxEditor Code Snippet
Dim oPart As PartDocument oPart = ThisDoc.Document Dim oCompDef As ComponentDefinition oCompDef = oPart.ComponentDefinition Dim oExtrude As ExtrudeFeatures oExtrude = oCompDef.Features.ExtrudeFeatures Dim oFaces As Faces oFaces = oExtrude.Item(1).Faces Dim oSketch As PlanarSketch Dim oSketch_1 As PlanarSketch Dim oSketch_2 As PlanarSketch '' This Just checks if the sketcj is already there... For y = 1 To oCompDef.Sketches.Count oSketch_1 = oCompDef.Sketches.Item(y) If InStr(oSketch_1.Name, "SIAPS") > 0 Then GoTo Endcode End If Next y ''Create the sketch oSketch = oCompDef.Sketches.Add(oFaces(1), True) Dim oSketchObjects As ObjectCollection oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection Dim oSketchEntity As SketchEntity For y = 1 To oCompDef.Sketches.Count oSketch_1 = oCompDef.Sketches.Item(y) If InStr(oSketch_1.Name, "Sketch") > 0 Then 'MessageBox.Show(oSketch_1.Name) oSketch_1.Name = "SIAPS" oSketch_1.Edit() For Each oSketchEntity In oSketch_1.SketchEntities If oSketchEntity.Type = 83898880 Then oSketchObjects.Add(oSketchEntity) 'MessageBox.Show(oSketchEntity.Type) End If Next Call oSketch_1.OffsetSketchEntitiesUsingDistance(oSketchObjects, 2, True, True) oSketch_1.ExitEdit() Exit For End If Next y Endcode : iLogicVb.UpdateWhenDone = True
