offset a new planar sketch projected geometry edge
cencinaNB2ET
cencinaNB2ET
Hello All,
I create a new sketch on an extrusion face with projected edges
Then i simply want to offset the boundary line of that sketch
I cant find anything similar anywhere that can collect those lines and offset it.
Here is what i have so far in Ilogic:
SyntaxEditor Code Snippet
Dim oPart As PartDocument
oPart = ThisDoc.Document
Dim oCompDef As ComponentDefinition
oCompDef = oPart.ComponentDefinition
Dim oExtrude As ExtrudeFeatures
oExtrude = oCompDef.Features.ExtrudeFeatures
Dim oFaces As Faces
oFaces = oExtrude.Item(1).Faces
Dim oSketch As PlanarSketch
Dim oSketch_1 As PlanarSketch
Dim oSketch_2 As PlanarSketch
'' This Just checks if the sketcj is already there...
For y = 1 To oCompDef.Sketches.Count
oSketch_1 = oCompDef.Sketches.Item(y)
If InStr(oSketch_1.Name, "SIAPS") > 0 Then
GoTo Endcode
End If
Next y
''Create the sketch
oSketch = oCompDef.Sketches.Add(oFaces(1), True)
Dim oSketchObjects As ObjectCollection
oSketchObjects = ThisApplication.TransientObjects.CreateObjectCollection
Dim oSketchEntity As SketchEntity
If InStr(oSketch_1.Name, "Sketch") > 0 Then
'MessageBox.Show(oSketch_1.Name)
oSketch_1.Name = "SIAPS"
oSketch_1.Edit()
For Each oSketchEntity In oSketch_1.SketchEntities
If oSketchEntity.Type = 83898880 Then
oSketchObjects.Add(oSketchEntity)
'MessageBox.Show(oSketchEntity.Type)
End If
Next
Call oSketch_1.OffsetSketchEntitiesUsingDistance(oSketchObjects, 2, True, True)
oSketch_1.ExitEdit()
Exit For
End If
Next y
Endcode :
iLogicVb.UpdateWhenDone = True
cencinaNB2ET
Sorry got it..
 it was just False, False
Call oSketch_1.OffsetSketchEntitiesUsingDistance(oSketchObjects, 2, False,False)
