Object reference error when activating a drawing
catherine28122001
Observer Observer
Message 1 of 8
catherine28122001
Observer
Observer
I wrote some code to make drawings of a part file using a template but I am running into this error: "Object reference not set to an instance of an object." when I try to activate a sheet of the DrawingDocument. Below is my code:
' Get the active part document
Dim partDoc As PartDocument
partDoc = ThisApplication.ActiveDocument
' Get the part file name without extension
Dim partFileName As String
partFileName = System.IO.Path.GetFileNameWithoutExtension(partDoc.FullFileName)
' Get the folder path of the part
Dim partFolderPath As String
partFolderPath = System.IO.Path.GetDirectoryName(partDoc.FullFileName)
' Specify the path to your drawing template file
Dim sortTemplatePath As String
sortTemplatePath = "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US\Standard.dwg"
' Create the drawing file name by appending ".idw"
Dim sortFileName As String
sortFileName = System.IO.Path.Combine(partFolderPath, partFileName & "-DRAWING.dwg")
' Get the active drawing document
Dim sortDwg As DrawingDocument
' Check if the drawing already exists
If System.IO.File.Exists(sortFileName) Then
    ' If the drawing exists, open it
	ThisDoc.Launch(sortFileName & DWGType)
Else
    ' If the drawing doesn't exist, create a new drawing from the template
    sortDwg = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,sortTemplatePath,True)
	'sortDwg = ThisApplication.Documents.Open(sortTemplatePath, False)
    ' Save the drawing with a new name
    sortDwg.SaveAs(sortFileName, False)
sortDwg.Activate() 'This is the line that gives me the error
Dim oSheet As Sheet = sortDwg.Sheets.Item(1)
 Any help would be appreciated! Thank you!
Replies (7)
Message 2 of 8
A.Acheson
Hi @catherine28122001
I am not seeing that specific error. Do you know what line it occurs on? Post the image of the more info tab. I do see a missing string variable. If you use Option Explicit On in the header it will flag any variables that have been incorrectly referenced.
Regards
Alan
Message 3 of 8
WCrihfield
Hi @catherine28122001.  I see the following line of code in 2 places:
...but I do not see where that 'DWGType' variable was created, or where a value was set to it.
Also, maybe try using ThisApplication.Documents.Open() method to open those drawings, instead of ThisDoc.Launch.  Just a suggestion.
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 8
Frederick_Law
'sortDwg not assigned any value
Message 5 of 8
catherine28122001
Observer
Observer
I removed it but am still getting the same error on the same line: line 40
Else
	ThisDoc.Launch(sortFileName)
Message 6 of 8
A.Acheson
Line 40 is to activate the drawing. This isn't always needed if you have the correct object open previously.
I would use this line
"ThisApplication.Documents.Open()" as Wesley has already suggested and just supply the filepath. If the file is already open you can use the active document to get the drawing object and do the next operation with it.
Regards
Alan
Message 7 of 8
catherine28122001
Observer
Observer
How do I get the drawing object? I found the segment of code below online and they activate, call out the sheets, and place the drawing. This code worked perfectly to put in the part but it doesn't load the template for some reason. The part just loads onto a blank sheet.
Dim oDoc As Document = ThisDoc.Document  ' Part Document or Assembly Document
Dim oSep As Double = 2
'Create a drawing from the drawing template
Dim oFileDlg As Inventor.FileDialog = Nothing
ThisApplication.CreateFileDialog(oFileDlg)
oFileDlg.Filter =  "Inventor Files (*.idw)|*.idw"
oFileDlg.DialogTitle = "Select Drawing Template"
oFileDlg.InitialDirectory = ThisApplication.FileOptions.TemplatesPath
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
	Exit Sub
ElseIf oFileDlg.FileName <> "" Then
MasterFile = oFileDlg.FileName
Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,templateFile,True)
oDrawingDoc.Activate()
Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
Dim oCentralPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width/2, oSheet.Height/2)
Dim oView As DrawingView
oView = oSheet.DrawingViews.AddBaseView(oDoc,oCentralPoint, 1, ViewOrientationTypeEnum.kBottomViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Dim V1Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X + 10, oView.Center.Y)
Dim V2Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Center.Y - 10)
Dim V3Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X + 10, oView.Center.Y - 10)
Dim oView1 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView, V1Point2D, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
Dim oView2 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView, V2Point2D, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
Dim oView3 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView, V3Point2D, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
oView1.Position= ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X + oView.Width / 2 + oSep + oView1.Width / 2, oView1.Center.Y)
oView2.Position = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Center.Y - oView.Height / 2 - oSep - oView2.Height / 2)
oView3.Position = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X + oView.Width / 2 + oSep + oView3.Width / 2, _
oView.Center.Y - oView.Height / 2 - oSep - oView3.Height / 2)
oView3.ViewStyle = oView.ViewStyle
Message 8 of 8
A.Acheson
The drawing object you can get using the add or open from the document collection see help page here.
I would suggest to review the help page as it gives additional information  on what arguments are optional and what each one does.
Syntax
Documents.AddDocumentType As DocumentTypeEnum, [TemplateFileName] As String, [CreateVisible] As Boolean ) As Document
Or
Syntax
Documents.OpenFullDocumentName As String, [OpenVisible] As Boolean ) As Document
Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Open("fullfilname",True)
In your new sample case I don't see you declaring and setting the filepath for the template file so this will be a null value. If you look at the add method the path is optional and if left empty what happens is an internal template is chosen and your customized one. This error can  either spotted  doing a code review and checking the path of each variable or  y using option Explicit On which h does a pre-screening for undeclared variables which can catch these errors before the code runs.
Regards
Alan
