Get Selected name from Vault Tab
LAD5
LAD5
I'm trying to get the name of the selected file in the Vault Tab, ex. "Corhole Board.idw". through the API.
I cant find the object it's in.  Does anyone have a sample code to get this name?
Lawrence
JelteDeJong
I don't have a vault installed but you could have a look at the following iLogic rule. Select a node in the vault browser and run the rule. It will find all browsers and log the selected node (if one is found)
        Dim doc As PartDocument = ThisDoc.Document
        For Each browserPane As BrowserPane In doc.BrowserPanes
            logger.Info(browserPane.Name & " - " & browserPane.InternalName)
            Dim topNode As BrowserNode = Nothing
            Try
                topNode = browserPane.TopNode
            Catch ex As Exception
                logger.Info("   None top node found.")
                Continue For
            End Try
            Dim selectedNode = GetSelectedNode(topNode)
            If (selectedNode IsNot Nothing) Then
                logger.Info("   " & selectedNode.BrowserNodeDefinition.Label)
            Else
                logger.Info("   None selected node found")
        Next
        logger.Info("- - - - - - or if you know the internal name of the browser - - - - - - - - -")
        Dim browser = doc.BrowserPanes.Item("PmDefault")
        Dim selectedNodeInBrowser = GetSelectedNode(browser.TopNode)
        If (selectedNodeInBrowser IsNot Nothing) Then
            logger.Info(selectedNodeInBrowser.BrowserNodeDefinition.Label)
        Else
            logger.Info("None selected node found")
    End Sub
    Public Function GetSelectedNode(node As BrowserNode) As BrowserNode
        If (node.Selected) Then Return node
        For Each refNode As BrowserNode In node.BrowserNodes
            Dim selectedNode = GetSelectedNode(refNode)
                Return selectedNode
        Next
        Return Nothing
    End Function
Jelte de Jong
Blog: hjalte.nl - github.com
LAD5
Sorry, this did not help.   This sample is also limited to the part document, i did switch to the Assmeblydocument but got the same results.   It found a Vault node, but said there was no node to access.
g.georgiades
The sample posted by @JelteDeJong only works if the DockedWindow/Browserpane is an Inventor tree browser. The vault panel has a custom GUI with a unique tree implementation which is why inventor says there is no top node found. There is currently no way to access the vault panel or read the tree.
Selecting items in the vault tree or in the model tree do seem to select their counterparts in the other tree - maybe that can help, though it seems to only be useful in assemblies.
Frederick_Law
Vault is in DockableWindow.
Sub Main()
'Dockable Windows
'Caption:InternalName
'Model:model
'iLogic Log:ilogic.logwindow
'iLogic:ilogic.treeeditor
'Vault:vault
'INFO|Model
'INFO|model
'INFO|H: 757 W: 302 T: 295 L: 74
'INFO|Docking State: 2
'INFO|Autodesk Inventor Professional 2023
'INFO|iLogic Log
'INFO|ilogic.logwindow
'INFO|H: 694 W: 230 T: 358 L: 1600
'INFO|Docking State: 4
'INFO|iLogic
'INFO|ilogic.treeeditor
'INFO|H: 218 W: 230 T: 115 L: 1600
'INFO|Vault
'INFO|vault
'INFO|H: 155 W: 302 T: 115 L: 74
'kDockBottom	1	Dock To bottom.
'kDockLastKnown	32	Docking To the last know state.
'kDockLeft		2	Docking To left.
'kDockRight		4	Docking To right.
'kDockTop		8	Docking To top.
'kFloat 		16	floating.
'Dim loggerWindow = ThisApplication.UserInterfaceManager.
'	DockableWindows.
'	Cast(Of DockableWindow).
'	Where(Function(d) d.InternalName.Equals("ilogic.logwindow")).
'	First()
'loggerWindow.Visible = True
Dim oDockableWindow As DockableWindow
Dim oDockingState As DockingStateEnum
Dim oDockToObject As Object
Dim ologgerWindow As DockableWindow
For i = 1 To 5
	oDockableWindow = ThisApplication.UserInterfaceManager.DockableWindows.Item(i)
	Logger.Info(oDockableWindow.Caption)
	Logger.Info(oDockableWindow.InternalName)
	Logger.Info("H: " & oDockableWindow.Height & " W: " & oDockableWindow.Width & " T: " & oDockableWindow.Top & " L: " & oDockableWindow.Left )
	oDockableWindow.GetDockingState(oDockingState, oDockToObject)
	Logger.Info("Docking State: " & oDockingState)
	'Logger.Info(oDockToObject.Caption & " " & oDockToObject.Type)
	'Logger.Info(oDockToObject.Parent.Type)
Next
End Sub
