Number plate Creation
mahesh_s493TE
Message 1 of 25
mahesh_s493TE
I want to create number plate based on the excel file.
Through iLogic program is created.
Sub main
	Dim oInvApp As Inventor.Application = ThisApplication
	Dim oDoc As Document = oInvApp.ActiveDocument
	If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
	Dim oAsmDoc As AssemblyDocument = oDoc
	Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	Dim oPart As ComponentOccurrence
	Try : oPart = oAsmDef.Occurrences.ItemByName("OriginalPart:1") : Catch : Exit Sub : End Try
	Dim oUParams As UserParameters = oAsmDef.Parameters.UserParameters
	Dim oParam As UserParameter
	Try : oParam = oUParams("FileLocation") : Catch
		oParam = oUParams.AddByValue("FileLocation", "", UnitsTypeEnum.kTextUnits) : End Try
	oParam.Value = GetFileLocation(oInvApp)
	If String.IsNullOrEmpty(oParam.Value) Then Exit Sub
	If Not IO.File.Exists(oParam.Value) Then Exit Sub
	Call CopyPipes(oPart, oParam.Value)
	oDoc.Update()
End Sub
Private Function GetFileLocation(ByVal oInvApp As Inventor.Application) As String
	Dim oFileDlg As Inventor.FileDialog = Nothing: oInvApp.CreateFileDialog(oFileDlg)
	oFileDlg.Filter = "Excel File (*.xlsx;*.xls)|*.xlsx;*.xls"
	oFileDlg.ShowOpen()
	Return oFileDlg.FileName
End Function
Private Function CopyPipes(oPart As ComponentOccurrence, ByVal sFileLoc As String)
	Dim sNameSheet As String = "Sheet1"
	Dim i As Integer = 2
	Dim slastPN, sCellValue As String
	Dim oPartDef As PartComponentDefinition = oPart.Definition
	Dim oPartDoc As PartDocument = oPartDef.Document
	Dim oSketch As PlanarSketch = oPartDef.Sketches("TextSketch")
	Dim oText As Inventor.TextBox = oSketch.TextBoxes(1)
	GoExcel.Open(sFileLoc, sNameSheet)
	Do
		slastPN = GoExcel.CellValue(sFileLoc, sNameSheet, "A" & i)
		If Not String.IsNullOrEmpty(slastPN) Then
			oPartDef.Parameters.UserParameters("Text").Value = slastPN
			oPartDoc.Update()
			oPartDoc.SaveAs("C:\Users\ValBrid106\Documents\Project\valbrid\LVAC\NAME PLATE\" & slastPN & ".ipt", True)
		i += 1
	Loop While Not String.IsNullOrEmpty(slastPN)
	GoExcel.Close()
End Function
 After run the program,
The following error message is occurred.
Error on line 40 in rule: Rule0, in document: PANEL NAME PLATE.iam
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
How will I modify the iLOGIC program., Kindly advice on this.,
Replies (24)
Message 2 of 25
CCarreiras
HI!
Only looking at the code will be hard to suggest something.
You have to share the files to yake a look and understand all the picture.
CCarreiras
Message 3 of 25
mahesh_s493TE
I need the name plate like below., In excel there is large of name plate to be create.
For the template creation, I make it like below.
Thanks.,
Message 4 of 25
batuhanozmen98
Hi, Can you SS your Fx parameter table?
Message 5 of 25
mahesh_s493TE
Message 6 of 25
mahesh_s493TE
This one or something else.,
Message 7 of 25
batuhanozmen98
Yes that one, the error at line 40 so can you change it like this:
oPartDef.Parameters.UserParameters("FileLocation").Value = slastPN
Message 8 of 25
mahesh_s493TE
The same error is occurred.,
Message 9 of 25
batuhanozmen98
I also need FX table of OriginalPart
Also can you try to replace line 40 with:
oText.Text = slastPN
Message 10 of 25
mahesh_s493TE
After modification the code, it is working fine., Thanks a lot.,
Message 11 of 25
batuhanozmen98
You are welcome
If this solved your problem, please click ACCEPT SOLUTION .
Message 12 of 25
mahesh_s493TE
One more needed in this Topic,
I need to maintain text size height - 7 mm, after completion of program, the text size changed to 3.05 mm.
Initially in the OriginalPart section, text size is 7mm.
How will I maintain text size constant? any solution is there, kindly reply.
Message 13 of 25
batuhanozmen98
the solution is you need to set FormattedText of textbox if you want to keep text properties of existing text.
oText.FormattedText = slastPN
Message 14 of 25
mahesh_s493TE
After updating of codes, the text height remains kept as 3.05mm.
Any other settings is there? kindly reply.
Message 15 of 25
batuhanozmen98
Like I said If you set the text height of originalPart to 7mm setting it with formattedText will not effect the height
Also you can set the font size with this piece of code:
oText.Style.FontSize = 7.0
Message 16 of 25
mahesh_s493TE
	Do
			oPartDoc.Update()
		i += 1
	GoExcel.Close()
End Function
After updating of program, the text size remains as 3.05mm.,
How will I proceed further?
Message 17 of 25
mahesh_s493TE
	Do
			oPartDoc.Update()
		i += 1
	GoExcel.Close()
End Function
Message 18 of 25
batuhanozmen98
try to swap these lines:
like this:
Message 19 of 25
mahesh_s493TE
			oPartDoc.Update()
		i += 1
	GoExcel.Close()
End Function
 After changed the codes & updating the program, the text size remains as 3.05mm.
What can I do?
Message 20 of 25
batuhanozmen98
At this point you may want to share some demo project that include your iLogic rule
