Number of bends of sheet metal part and direction
Ahmed.shawkyXTZHN
Message 1 of 14
Ahmed.shawkyXTZHN
Hi All ,
is it possible to get number of bends for sheet metal parts and and how many bends up and how many down to be shown in drawing as a table , thanks.
Replies (13)
Message 2 of 14
JelteDeJong
You can try this:
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim refDoc As PartDocument = sheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
Dim refDef As SheetMetalComponentDefinition = refDoc.ComponentDefinition
Dim flatPattern = refDef.FlatPattern
Dim ups = 0
Dim downs = 0
For Each result As FlatBendResult In flatPattern.FlatBendResults
    If (result.IsOnBottomFace) Then Continue For
    If (result.IsDirectionUp) Then
        ups += 1
    Else
        downs += 1
    End If
Next
Dim insertPoint = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
Dim headers = New String() {"Direction", "number"}
Dim table = sheet.CustomTables.Add("Bends", insertPoint, 2, 2, headers)
table.Rows.Item(1).Item(1).Value = "Up"
table.Rows.Item(1).Item(2).Value = ups
table.Rows.Item(2).Item(1).Value = "Down"
table.Rows.Item(2).Item(2).Value = downs
Jelte de Jong
Blog: hjalte.nl - github.com
Message 3 of 14
JelteDeJong
You also might want to have a look at my blog post: Automatically generate bend dimensions
Jelte de Jong
Message 4 of 14
Ahmed.shawkyXTZHN
thanks for your response , it's working fine with part , is it possible that it can run from assembly so all will come in one table along with cutting list , thanks.
Message 5 of 14
JelteDeJong
try this:
Public Class ThisRule
    Sub Main()
        Dim refDoc As Document = sheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
        Dim infos As New List(Of DocumentInfo)
        If (refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
            If (refDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
                infos.Add(New DocumentInfo(refDoc))
            End If
        Else
            For Each assDoc As Document In refDoc.AllReferencedDocuments
                If (assDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
                    If (assDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
                        infos.Add(New DocumentInfo(assDoc))
                    End If
                End If
            Next
        End If
        If (infos.Count = 0) Then
            MsgBox("No sheetmetal found.")
            Return
        End If
        Dim headers = New String() {"Part", "Size", "Up", "Down"}
        Dim table = sheet.CustomTables.Add("Bends", insertPoint, headers.Length, infos.Count, headers)
        For i = 1 To infos.Count
            Dim row = table.Rows.Item(i)
            Dim info = infos.Item(i - 1)
            row.Item(1).Value = info.DisplayName
            row.Item(2).Value = info.Size
            row.Item(3).Value = info.Ups
            row.Item(4).Value = info.Downs
        Next
    End Sub
End Class
Public Class DocumentInfo
    Public Sub New(doc As PartDocument)
        Dim uom = doc.UnitsOfMeasure
        Dim def As SheetMetalComponentDefinition = doc.ComponentDefinition
        Dim flatPattern = def.FlatPattern
                Ups += 1
            Else
                Downs += 1
            End If
        Next
        Dim width = uom.ConvertUnits(flatPattern.Width, UnitsTypeEnum.kDatabaseAngleUnits, UnitsTypeEnum.kDefaultDisplayAngleUnits)
        Dim length = uom.ConvertUnits(flatPattern.Length, UnitsTypeEnum.kDatabaseAngleUnits, UnitsTypeEnum.kDefaultDisplayAngleUnits)
        Size = String.Format("{0}x{1}", Math.Round(width, 5), Math.Round(length, 5))
        DisplayName = doc.DisplayName
    End Sub
    Public Property Ups As Integer = 0
    Public Property Downs As Integer = 0
    Public Property Size As String
    Public Property DisplayName As String
End Class
Jelte de Jong
Message 6 of 14
Ahmed.shawkyXTZHN
Thanks A lot , it's working great , sorry for bothering you can the outputs be as custom property so I can added to existing table  , below is snap for the table  , thanks in advance.
Message 7 of 14
Ahmed.shawkyXTZHN
If it can be custom it I will be able to added to existing designs tables , thanks.
Message 8 of 14
Ahmed.shawkyXTZHN
@JelteDeJong  If it is not possible to make as custom property can we remove the part extension , thanks.
Message 9 of 14
Ahmed.shawkyXTZHN
@JelteDeJong Is it possible ?, thanks.
Message 10 of 14
Ahmed.shawkyXTZHN
Hi @JelteDeJong  with reference to above conversation is it possible have the number of bending sides of sheet metal part , for example if there is 4 edges and only 2 edges have flanges it will mentioned that number of bends sides is 2, thanks.
Message 11 of 14
Ahmed.shawkyXTZHN
Hi @Andrii_Humeniuk  ,
I saw one post similar to this one solved by you but couldn't find it didn't work to provide the required result , could you support me for that issue.
Message 12 of 14
JelteDeJong
This will fill the properties "ups" and "downs".
Public Sub main()
    For Each refDoc As Document In doc.AllReferencedDocuments
        If (refDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then Continue For
        If (refDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Continue For
        Dim def As SheetMetalComponentDefinition = refDoc.ComponentDefinition
        If (Not def.HasFlatPattern) Then
            def.Unfold()
        End If
        Dim ups = 0
        Dim downs = 0
                ups += 1
            Else
                downs += 1
            End If
        Next
        SetCustomProperty(refDoc, "Ups", ups)
        SetCustomProperty(refDoc, "Downs", downs)
    Next
End Sub
Public Sub SetCustomProperty(doc As Document, name As String, value As String)
    Dim propSet = doc.PropertySets.Item("Inventor User Defined Properties")
    Try
        propSet.Item(name).Value = value
    Catch ex As Exception
        propSet.Add(value, name)
    End Try
End Sub
Jelte de Jong
Message 13 of 14
Ahmed.shawkyXTZHN
Hi @JelteDeJong  thanks for your quick response , sorry for the confusion , is it possible to get how many sides has bend for example the below part has 4 edges so all edges will have 4 bends .
Message 14 of 14
Ahmed.shawkyXTZHN
Hi @JelteDeJong  is it possible to get the same , number of sides
