New to Inventor
New to Inventor
jeslinakoruth
New to Inventor
jeslinakoruth
I am having some trouble with my code. Any ideas on what is going wrong?
' Prompt the user for the part OD
Dim partOD As Double
partOD = CDbl(InputBox("Enter the Part OD:", "Part OD Input"))
' Set dimensions based on part OD
If partOD > 0 And partOD <= 2.25 Then
    size = 3.5
    sizec = 3.5
    sizeb = 3.5
    sizet = 3.5
ElseIf partOD > 2.25 And partOD <= 3.5 Then
    size = 4.75
    sizec = 4.75
    sizeb = 4.75
    sizet = 4.75
ElseIf partOD > 3.5 And partOD <= 4.5 Then
    size = 6.0
    sizec = 6.0
    sizeb = 6.0
    sizet = 6.0
ElseIf partOD > 4.5 And partOD <= 6.25 Then
    size = 7.75
    sizec = 7.75
    sizeb = 7.75
    sizet = 7.75
ElseIf partOD > 6.25 And partOD <= 8.0 Then
    size = 9.75
    sizec = 9.75
    sizeb = 9.75
    sizet = 9.75
ElseIf partOD > 10 And partOD <= 12 Then
    size = 14.0
    sizec = 14.0
    sizeb = 14.0
    sizet = 14.0
' Set other dimensions based on the sizes
If size = 3.5 Then
    zdiameter = 3.245
    zdiameterc = 3.245
    zdiameterb = 3.245
    zdiametert = 3.245
    maxpindiameter = 1.125
    maxpindiameterc = 1.125
    maxpindiameterb = 1.125
    maxpindiametert = 1.125
ElseIf size = 4.75 Then
    zdiameter = 4.495
    zdiameterc = 4.495
    zdiameterb = 4.495
    zdiametert = 4.495
ElseIf size = 6.0 Then
    zdiameter = 5.745
    zdiameterc = 5.745
    zdiameterb = 5.745
    zdiametert = 5.745
    maxpindiameter = 1.5
    maxpindiameterc = 1.5
    maxpindiameterb = 1.5
    maxpindiametert = 1.5
ElseIf size = 7.75 Then
    zdiameter = 7.495
    zdiameterc = 7.495
    zdiameterb = 7.495
    zdiametert = 7.495
    maxpindiameter = 1.75
    maxpindiameterc = 1.75
    maxpindiameterb = 1.75
    maxpindiametert = 1.75
ElseIf size = 9.75 Then
    zdiameter = 9.495
    zdiameterc = 9.495
    zdiameterb = 9.495
    zdiametert = 9.495
    maxpindiameter = 1.875
    maxpindiameterc = 1.875
    maxpindiameterb = 1.875
    maxpindiametert = 1.875
ElseIf size = 14.0 Then
    zdiameter = 13.745
    zdiameterc = 13.745
    zdiameterb = 13.745
    zdiametert = 13.745
    maxpindiameter = 2.75
    maxpindiameterc = 2.75
    maxpindiameterb = 2.75
    maxpindiametert = 2.75
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("size").Value = size
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("sizec").Value = sizec
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("sizeb").Value = sizeb
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("sizet").Value = sizet
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiameter").Value = zdiameter
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiameterc").Value = zdiameterc
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiameterb").Value = zdiameterb
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("zdiametert").Value = zdiametert
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxindiameter").Value = maxpindiameter
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxpindiameterc").Value = maxpindiameterc
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxpindiameterb").Value = maxpindiameterb
ThisApplication.ActiveDocument.ComponentDefinition.Parameters.Item("maxpinDiametert").Value = maxpindiametert
Frederick_Law
Would be nice to know what kind of trouble you have with your code.
What is it supposed to do?
A.Acheson
How long is a piece of string? These are all custom parameters so unless we create them all we won't know what's going on. You direct and we can offer advice.
Regards
Alan
jeslinakoruth
It keeps saying catastrophic error, and it also says value is not double.
jeslinakoruth
It's supposed to generate a shape using these dimensions I have edited on the drawing.
jeslinakoruth
I created some parameters on the drawing I am generating, but I am confused on how to connect them if needed. I have named them using names such as "size, sizet, zdiameter, etc."
A.Acheson
I think you might need to offer some more images or clarifications as to what you would like to achieve.
In this section your setting the parameter value to itself using the Inventor API(left) and maybe the Ilogic API ( right). Are you using a local rule or a global rule? Can you share an image?
Regards
Alan
